What should I expect??
#819490
10/02/10 12:41 AM
10/02/10 12:41 AM
Posts: 279 hartsburg mo
biggerredz71
hartsburg mo
Im going to be taken the 70 RoadRunner to track for the first time!I dont know what to expect.All steel body car with a glass hood,505 stroker,stealth heads,victor intake,250-255 dur@50 576-593 lift hyd flattappet cam,prosystems 1000hp carb,2"hooker headers with 3" pipe and flowmasters dumped at rearend.This will be on 295-50-15 street tires and no sub frame connectors. Am I wasting my time? I forgot 4200 stall and 3:55 gears. If it hooks what kind of times should I be looking for? Thank's
Re: What should I expect??
[Re: biggerredz71]
#819491
10/02/10 01:31 AM
10/02/10 01:31 AM
Posts: 5,221 Branson, Mo.
joedust451
super gas
super gas
Branson, Mo.
Im going to be taken the 70 RoadRunner to track for the first time!I dont know what to expect.All steel body car with a glass hood,505 stroker,stealth heads,victor intake,250-255 [Email]dur@50[/Email] 576-593 lift hyd flattappet cam,prosystems 1000hp carb,2"hooker headers with 3" pipe and flowmasters dumped at rearend.This will be on 295-50-15 street tires and no sub frame connectors. Am I wasting my time? I forgot 4200 stall and 3:55 gears. If it hooks what kind of times should I be looking for? Thank's
I'll bet it "doesn't" hook with those tires if there just a radial, put some tires on it so you can run the #s, i would definitly install SFCs & weld them in, its hard to say what it will run, depends on what it weighs with you in it, but i'll venture to say 11.2/11.3s at 118, thats my guess
