Re: Vibrations in drivetrain
[Re: JonC]
#819259
10/01/10 08:51 PM
10/01/10 08:51 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
what size of engine is it?
Have you ever check the rear pinion angle?
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: Mopar_Country]
#819262
10/01/10 09:22 PM
10/01/10 09:22 PM
Posts: 3,623 Millinocket, Maine
JonC
Millinocket, Maine
I had the car on my lift with the axles out and at ride height. The driveshaft I thought was too short so I had a new one made with about 3/4" to go before it would jam.
11B40
[Re: JonC]
#819268
10/01/10 10:54 PM
10/01/10 10:54 PM
Posts: 893 Tustin, CA
pishta
Tustin, CA
the vibrations changed when I changed gear ratios. But it was the speed where they occurred that changed not rpm.
If its is Speed related then it must be in the diff, but if it is RPM related its in the driveline. You knocked the weights off the external balanced convertor..some of those were to balance it neutrally too. It would show itself in neutral too.
[Re: RapidRobert]
#819269
10/02/10 02:07 PM
10/02/10 02:07 PM
JonC
Millinocket, Maine
eng balance/TC prob
That basically is what I asked in the original post, what kind of vibrations would I experience if I had neutral balanced converter and damper with a cast crank.
