V10 truck died follow up #819223
10/01/10 08:01 PM
10/01/10 08:01 PM
NC
BillNC Offline OP
BillNC  Offline OP
NC
My earlier post talked about my 2500 dying on the road. After Replacing crank sensor which was broken during diagnosis, engine had both fire and fuel but still would not run. No codes. When replacing plugs, decided to look into oil filler hole. Guess what. When cranking engine, only front rockers move. Broken camshaft? That's my guess. Any other ideas? Has anyone heard of broken camshafts in v10s?
Re: V10 truck died follow up [Re: BillNC] #819224
10/01/10 08:04 PM
10/01/10 08:04 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
By golly, I think you've found it!
A quickie Google search didn't find anything but my google-fu is lacking.
- Stu Harmon
Re: V10 truck died follow up [Re: feets] #819225
10/01/10 11:19 PM
10/01/10 11:19 PM
Tustin, CA
P
pishta Offline
pishta  Offline
P
Tustin, CA
buddy broke a camshaft, the oil galley plugged and the bearing seized, seized up the camshaft and the thing sheared when the chain was stronger than the cam.
