Valve Lash Settings
#819218
10/01/10 07:32 PM
10/01/10 07:32 PM
Posts: 59 kansas
70B5Vert
kansas
So whats the thoughts on V/L settings?
I have stage6 aluminum heads, a Hughes 594/605 Cam. crane 1.6 roller rockers. Cam chart says set lash at 18/20 hot. We set the lash initially at 22/24 cold.
We were subsequentially told to set cold lash setting .004 tighter than the Hot setting. ( .014/.018)
Is this correct??
Just wondering.
Car ran well at the looser setting.
Thanks in advance
Deron
Re: Valve Lash Settings
[Re: 70B5Vert]
#819220
10/01/10 08:59 PM
10/01/10 08:59 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
Is this correct??
Just wondering.
Thanks in advance
Deron
You've gone the wrong direction. The heads and block grow, which ADDS to the lash. When setting cold lash, you need to go 4-6 thousandths TIGHTER than warm. With alum. Heads, hit the igh side of that. If lash reccomendation calls for 18-20 warm, you should be at about 12-14 cold.
Where you're at now, when hot your at nearly .030!
