Questions About Welding?? #818583
09/30/10 08:03 PM
09/30/10 08:03 PM
440charger70 Offline OP
super street
super street
I have 2 questions about welding to make sure this is the last time I see this steel for a long time...
Question 1: I have heard that welds are prone to rusting under paint. Is there something I should put over my welds before I prime over them?
Question 2: Is there a product I can put over my (butt) weld seams incase I miss any pinholes that will prevent moisture from coming through and bubbling the bondo, primer & paint above?
Thanks as always!!!
Re: Questions About Welding?? [Re: 440charger70] #818584
09/30/10 10:59 PM
09/30/10 10:59 PM
Greenville, N.C.
BarrsRestoration Offline
Greenville, N.C.
We sandblast ALL welds, then apply epoxy primer. I hold a light behind the weld to see if there are any pinholes before priming.
Steve
www.clarkclassic.com
Re: Questions About Welding?? [Re: 440charger70] #818585
09/30/10 11:19 PM
09/30/10 11:19 PM
S.E. WI
RichL1967 Offline
RichL1967  Offline
S.E. WI
They make weld through primer. Bloxide Weldable Primer or copper weldthru primer or Cold Galvanizing Compound. Do a search at eastwood.com for the particulars on each.
Cheers
Common sense and caution are factors which cannot be built into any product. These must be supplied by the operator.
Re: Questions About Welding?? [Re: RichL1967] #818586
10/01/10 09:54 AM
10/01/10 09:54 AM
New Hampshire
W
whitemtnelf Offline
whitemtnelf  Offline
W
New Hampshire
I tried Rustoleum's cold galvanizing and the welds were porous. I now use SEM's weld through primer and am happy with the results.
Re: Questions About Welding?? [Re: 440charger70] #818587
10/01/10 11:18 AM
10/01/10 11:18 AM
O
OLD318 Offline
OLD318  Offline
O
Thanks as always!!!
1. Your welds will rust through if they are not dressed properly after welding. Grind them smooth and/or sand blasting will cure this...
2. As for the pinholes. the best way is to put a light behind the panel and turn off the lights in the garage.... Use your MIG to fill any pinholes and then grind/sandblast before priming.
Spray it with 2 coats of epoxy primer after this is finished. Then do any necessary filler work..
Just my
