Sonic checking a block #818439
09/30/10 12:34 PM
09/30/10 12:34 PM
SD800 Offline OP
SD800  Offline OP
What does it cost? and any place in Michigan that does it? the closer to Traverse City the better.
You'll have plenty of time to sleep when your dead, let's go
Re: Sonic checking a block [Re: SD800] #818440
09/30/10 12:41 PM
09/30/10 12:41 PM
Oak Grove, MN
lowflyingdart Offline
Oak Grove, MN
We charge $75.00. We check each cylinder in 12 spots and plot it on a worksheet. But we are in MN.
"I have not failed. I've just found 10,000 ways that won't work." Thomas A. Edison
Re: Sonic checking a block [Re: SD800] #818441
09/30/10 12:45 PM
09/30/10 12:45 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
We charge $50 for spot checking and $100 for a complete 12 spot per bore check.If we are doing the build N/C(part of the build).
