Help with 6-pack power brake proportioning valve ? #818349
09/30/10 10:50 AM
09/30/10 10:50 AM
Texas
Texican Offline OP
Texican  Offline OP
Texas
Hello
Does anyone have a diagram / schematic of the power brake proportioning valves (both of them) for a 6 pack challenger with front disc brakes & rear 10" drums...
I have 2 brass valves as follows:
One of them has an inlet with 4 outlets (5 ports)
One of them has an inlet with 2 outlets (3 ports)
Thanks for any help.
Mike
Help with 6-pack power brake proportioning valve ? [Re: Texican] #818350
10/01/10 12:42 AM
10/01/10 12:42 AM
Texas
Texican Offline OP
Texican  Offline OP
Texas
Bump
Help - Anyone ?
Re: Help with 6-pack power brake proportioning valve ? [Re: Texican] #818351
10/01/10 09:06 AM
10/01/10 09:06 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Put this in the resto forum , also note there is no difference between 6pk and every other 70 E body with disc brakes .
Also do a search in the resto forum as this topic has been brought up in the recent past.
Re: Help with 6-pack power brake proportioning valve ? [Re: Texican] #818352
10/01/10 09:12 AM
10/01/10 09:12 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
no idea, I bought an expensive "correct" PV for my car that LEAKED! I went with the summit adjustable PV and have had zero issues. Mines Manual disc not sure if that makes a difference.
Coming soon!!!!
Re: Help with 6-pack power brake proportioning valve ? [Re: Mr.Yuck] #818353
10/01/10 09:25 AM
10/01/10 09:25 AM
n/w, PA
demonH1B Offline
demonH1B  Offline
n/w, PA
I think this is what you need.
Re: Help with 6-pack power brake proportioning valve ? [Re: Mr.Yuck] #818354
10/01/10 11:10 AM
10/01/10 11:10 AM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I bought the expensive correct replacement for mine too from Fine Lines that leaked as well. They exchanged it for another on & has been O.K. since.
As mentioned above there is no six pack specific p.v. it all depends on if you have manual 4 wheel drum, manual front disc rear drum or front power disc & rear drum brakes that makes the difference in the p.v.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Help with 6-pack power brake proportioning valve ? [Re: 6PKRTSE] #818355
10/01/10 11:12 AM
10/01/10 11:12 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I guess I could have returned it too except after re-flairing lines and re- mounting it and double checking everything because I though I made the problem I thru it accross the garage against a brick wall. Good thing I was using DOT5 fluid. That thing cost me like 3 weekends of aggravation.
