Engine Carnage... Would you say bad luck? Long story
#818152
09/30/10 12:13 AM
09/30/10 12:13 AM
Posts: 1,064 Tennessee
727builder
Tennessee
A few weeks ago a friend of mine wanted me to drive his 66 coronet in footbrake class at a little 1/8 track. It's a 400 stroked to 512 with indy ez heads. I haven't been in it in about 6-7 months. Ran a 6.33 then with a 1.35 60ft. Was cool weather back then. Car is right @ 3600 lbs with me in it. Temp outside was high 80's to low 90's. Before the first pass I told him I was guessing it would run a 6.41 on my first pass. I had a 015 light and ran a 6.417. 2nd time trial we figured it would run a 6.40. It did and i had a 045 light. I Missed the bulb some... We figured last time trial would get a 6.39 out of it. Ran a 6.39 and i was 035 on the tree. Here's where it went bad. 4th pass was to be run for the money. We dialed it on 6.39. I ran a slower 8 sec pick up so i waited for my side of the tree to come down and i left with a 026 light and half track she just shut off, He said he saw some fire thru the headers as she died. I was thinking as i coasted it back to his pit stall that the valve train stopped. Pulled the dist cap and sure enough rotor didn't turn as we turned the crank. Got it apart and found this.....
Re: Engine Carnage... Would you say bad luck? Long story
[Re: Labratt]
#818161
09/30/10 01:11 AM
09/30/10 01:11 AM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
Considering what could have been I'ld say you guys got lucky.
Could have been much worse.
Glad it's not though
[Re: Labratt]
#818162
09/30/10 01:11 AM
09/30/10 01:11 AM
727builder
Tennessee
Carl..in no way was I blaming Indy for the failure of the motor! Not with what you showed,and just explained! Thank God you caught it before the pick-up tube broke off!
I didnt think you was bashing. And No way was blaming indy for the chain breaking. We think that was from cam walking in and out. Just glad he found the problem with the pick up tube and the shims under the valve springs. Could have been a lot worse damage if that pick up tube broke off during a pass.
[Re: Labratt]
#818164
09/30/10 11:00 PM
09/30/10 11:00 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
i'm a glass half full guy so i will say you got lucky.
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: sixpackgut]
#818166
10/01/10 01:17 AM
10/01/10 01:17 AM
Posts: 996 Queens, New York
Harley
Queens, New York
100%
