How much punishment can a 7 1/4 rear take?
#818128
09/29/10 11:41 PM
09/29/10 11:41 PM
Posts: 130 Winterville, Ga USA
rogue_leader007
Winterville, Ga USA
I'm dropping a 360 in place of my slant 6 and was wondering how the 7 1/4 rear would hold up.
The 360 will get headers, cam, intake, and new carb. It's an '83 4bbl motor. From the article I'm following it should put out around 327 hp and close to 400 ft-lbs of torque. (wishful thinking, maybe?)
How long would the rear last under normal around-town driving? Not really planning to race at this time.
Glad to be back in the hobby. 68 Plymouth Valiant
Re: How much punishment can a 7 1/4 rear take?
[Re: 1_WILD_RT]
#818131
09/29/10 11:49 PM
09/29/10 11:49 PM
rogue_leader007
Winterville, Ga USA
Kinda figured. Does anyone make stouter components for the 7 1/4? I'd hate to just go to pass a slower car and blow the rear end.
[Re: rogue_leader007]
#818132
09/29/10 11:56 PM
09/29/10 11:56 PM
RapidRobert
I'm going to try running one in a circle burner 360 (2bbl 9-1 CR class rules) w 4:10 gears in 2nd gear (904 1.45). It'll save maybe 100 lbs over an 8&3/4 (if it holds up). The weakest link is the spider gears and Randy's R&P has them
[Re: 440newport]
#818135
09/30/10 12:13 AM
09/30/10 12:13 AM
rogue_leader007
Winterville, Ga USA
2 weeks? lol. Hopefully I can make mine last longer, or at least until I get all the parts to install my 8 3/4.
[Re: dOOc]
#818137
09/30/10 01:01 AM
09/30/10 01:01 AM
Posts: 12,481 Chino Valley
RodStRace
Chino Valley
70 barracuda 318 2 bbl. 2.76 gears. less than a year back in the 80s.... Playing a little in water did it, spider gears.
[Re: Evil Monkey]
#818141
09/30/10 08:23 AM
09/30/10 08:23 AM
Posts: 5,907 Athens, Greece
Pyper70
Athens, Greece
I shredded the spider gears on my 70 Dart...7 1/4"...with a slant 6....At the time..I hadn't made too many mods...just a 6-to-1 header, Offy 4bbl Intake and a 4bbl 390cfm, 904 was stock. I left from the first stop sign from my house, just normal driving and the whole car went KA-CHUNK! and the whole rear of the car jumped to the right...I babied her back one block....
I dropped in my buddies 70 Charger 8 3/4, had him rebuild the 3.23's...slipped right into place no cutting, welding, narrowing...
7.25's are about the biggest abomination Chrysler put out...if a slant 6 can kill it....your 360 will annihilate it
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
#818142
09/30/10 09:30 AM
09/30/10 09:30 AM
Posts: 1,255 Columbus, GA
Michael Ecks
Columbus, GA
It's been too many years to remember exactly how long it lasted when I switched my 318 e-body to a mild 360. But it wasn't long. When mine decided to go, it actually cracked one side of the ring gear carrier, allowing enough clearance to shoot a spider gear partially through the back cover. It locked up momentarily in the middle of a curve on the way home, causing the rear end of the car to slide sideways pretty violently. If it hadn't blown all the way out allowing the rear tires to spin freely (no power to them anymore) then it probably would have made for a pretty bad wreck. Save yourself the pucker factor and get your 8 3/4 finished before you put it back on the road.
"The happiness of your life depends upon the quality of your thoughts" ~ Roman Emperor Marcus Aurelius
[Re: Michael Ecks]
#818143
09/30/10 10:33 AM
09/30/10 10:33 AM
Posts: 3,897 St. Louis, MO
Blues_Cuda
St. Louis, MO
My first car was a '68 Valiant 100. While a senior in high school, I put in a 360/727 over Christmas break. I did not have the funds for an 8 3/4 at the time, so I left the 7 1/4 in it for about 6 months. It was driven daily and spun the tire fairly easily. When I finally upgraded to an 8 3/4, the 7 1/4 was toast. It never failed to the point of where the car could not be driven, but it made all sorts of noises. The car was far from fast and never had a sticky tire on it, but I was the 16 yr old loose nut behind the wheel. (Car ran 13's at the track.) One thing that I do miss...the fact I could go to a local junkyard and find a 3.55 Sure Grip A-body 8 3/4 for $50.
[Re: polkat]
#818145
09/30/10 10:59 AM
09/30/10 10:59 AM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
I ran a 7-1/4 behind a mildly built 318 for a while. It was a few years ago when I hecame unemployed, so instead of swapping in a new rear, I decided to run it till it went (which would force me into getting another). But for the next two years I had it, the rear never blew! Sold it that way (told the new owner of course).
Same storey here. Broke a few with slant 6's and stock 318's. Darts, Diplomats, Dusters etc.
Threw a 383 Dart together. 12 sec piece. The 7 1/4 was the last thing to get swapped out. So we threw on the slicks and tried to break it. She was lifting the front wheel off the ground and never broke.
Swapped in an 8 3/4 later for fear of breaking the tiny 7 1/4 at an less opportune time. Oddly enough many years later we stripped the spline in the 8 3/4. All the Mopar visitors would bow as they walked past the 7 1/4 sitting outside of the garage in the scrap pile.
[Re: Magnum]
#818146
09/30/10 11:47 AM
09/30/10 11:47 AM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
I built a detuned 360 4bbl and threw it in my 66 dart and blew the rear pretty quick. I put a 2bbl 360 cam in it and 302 casting heads and ran it through the stock 273 2bbl manifolds. It actually ran faster with the 302 heads than the 360 heads. The suregrip will actually help the 7.25 because it keeps those spider gears from spinning so fast when the one tire breaks traction. I think if someone made a spool for them or aftermarket sure grip it would help them live a lot longer.
