Re: How much compression is really enough? [Re: moparniac] #818101
09/30/10 09:43 PM
09/30/10 09:43 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
LOOK at what A BUNCH of the other guy's combos are ... over 11 to 1 ...
I say ... CHANGE yerr engine builder !!
Re: How much compression is really enough? [Re: dOc !] #818102
09/30/10 10:06 PM
09/30/10 10:06 PM
Dunedin, Fl
DRDart Offline
mopar addict
DRDart  Offline
mopar addict
Dunedin, Fl
16-1 Might be too much
[image]http://i682.photobucket.com/albums/vv183/DrDart500/DSC00307.jpg 1966 Charger 1970 Dart 16-1,solid roller,500 ci Tunnel Ram 8" Ati conv,BTE glide, Fab 9 rear strange center sect. Twin Rons terminators on Alky.
Re: How much compression is really enough? [Re: DRDart] #818103
09/30/10 10:15 PM
09/30/10 10:15 PM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
NOT running E85 and a big gear and open headers !!
Re: How much compression is really enough? [Re: dOc !] #818104
09/30/10 10:27 PM
09/30/10 10:27 PM
Az
Crizila Offline
Crizila  Offline
Az
Sure, diesel motors do it all the time. Coarse there bottom ends are a little stouter than our stuff
Fastest 300
Re: How much compression is really enough? [Re: Crizila] #818105
09/30/10 10:33 PM
09/30/10 10:33 PM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
I knew a guy in Detroit who was running a RED with an RB engine ...pure alky running something in the neighborhood of 16-18 to 1 ..IIRC. Stock block I think.
Re: How much compression is really enough? [Re: frank] #818106
09/30/10 10:34 PM
09/30/10 10:34 PM
Az
Crizila Offline
Crizila  Offline
Az
fuel will be pump 91 octaine. I don't want to use more compression than I need. I don't know if 9.5:1 will get me there or not
Personnally, I would not go over 10.1 with 91 octane fuel. You should have enough motor to get you where you want to go at 9.5.
Fastest 300
Re: How much compression is really enough? [Re: frank] #818107
09/30/10 11:59 PM
09/30/10 11:59 PM
tucson az
frank Offline OP
frank  Offline OP
tucson az
Thank you for your replies. The cam I was looking at is a Comp hyd roller
549/544 lift
242I 248E duration at .050
Again thanks
Re: How much compression is really enough? [Re: frank] #818108
10/01/10 12:43 AM
10/01/10 12:43 AM
I forgot to mention, besides I had rambled on long enough on that post, that when I hopped my 512 up three years later I had switch cylinders heads from the big valve ported iron 906 heads (OEM productions ones) to a set of Eddy RPM CNC ported by Jeff at MCH and I swapped the crank out from the Ohoi Crankshaft CO. crank 4.25 stroke to a Chinese imported 6 bolt 4.150 440 crank that I had offset ground to 4.300 stroke(+.050 ) and modified to match the balance and clear in my motor by the same shop that had prepared the 4.25 origunally. It bolted right in with no hassles at all That moved the 22.0 cc dihed piston from -.025 in the cylinders to zero deck bumping the compression from 9.25 to to 10.29 to 1, it also increased the C.I. from 512 to 518. I reused the same rings, bearings, rods and pistons and the head gaskets No other changes other than the crankshaft and cylinder heads. I had swapped the cylinder heads onto the motor the previuos winter Those heads pick the cars ET and MPH up by about .3 ET and almost three MPH I dyno tested the motor here in Oregon during the winter of 2006- 2007 on the local Studka engine dyno using Oregon 92 octane pump gas bought at a local Chevron station, nothing special The motor made a best of 718 to 720 HP at 5800 RPM on two different days and 644 FT lbs at 4700 RPM several times This is the same Comp Cams solid roller as before, 260 degrees at .050 intake ground on 108 LSA with .710 net lift at the retainers using the Harland Sharp 1.6 ratio rockers( which measured out to be 1.65 net actual ratios ) Put the biggest street and strip shelf cam you can get or contact me if you want a really good custom ground hydraulic roller cam made
Re: How much compression is really enough? [Re: johnzgarage] #818109
10/01/10 03:01 AM
10/01/10 03:01 AM
California
BigDaddy440 Offline
BigDaddy440  Offline
California
Dont get to hung up on base or static compression ratio. You have to really focus in on your cam grind .......that will give you your dynamic compression ratio, which will make or break your street combo.
^ This.
I had a stock stroke 440 with 11:1 static, but absolutely no real compression. I could have ran 87 octane with 36* total advance in 100 degree weather without a ping or problem.
You need to calculate your Dynamic Compression accurately with different pistons and cam profiles. If you're planning on running pump gas, you'll want your D.E. compression to be in the low to mid 8s and no higher.
-dan
1969 A12 Roadrunner
1970 Plymouth Cuda
1968 Dodge Dart
Re: How much compression is really enough? [Re: frank] #818110
10/01/10 12:26 PM
10/01/10 12:26 PM
NC
440Jim Offline
440Jim  Offline
NC
549/544 lift
Again thanks
That will be real mild in a 500 inch motor. They like to eat duration for breakfast. IMO, cam duration and compression ratio depend on each other. Also remember aluminum heads will tolerate CR (octane need) better than iron heads. And I think your altitude will tolerate a bit more CR than sea level also. Also, when comparing duration of a solid lifter cam to a hydraulic, the lash of the solid lifter will make the duration "feel" smaller, maybe 5-7 degrees? So a solid 260 might feel more like a hydraulic 253.
My street car 440 has iron heads at sea level (80 ft), 257 deg solid lifter flat tappet cam, IRON heads, and 10.75 CR. Pump gas all the way.
For your application, 260ish duration at 0.050" solid lifter cam, 11.0 CR (10.5 is OK with the smaller cam). You could likely get away with even more CR, so I think this is conservative and will work great.
Re: How much compression is really enough? [Re: 440Jim] #818111
10/01/10 12:30 PM
10/01/10 12:30 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
very small cam, i would shoot for 11.1 and a cam in the mid 250's or better @.050. that should get you around 175 or so cranking psi, fine for 91-93.
Re: How much compression is really enough? [Re: ademon] #818112
10/01/10 01:52 PM
10/01/10 01:52 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Why straight pump gas in your hotrod? How many tankfuls of gas are you planning on burning through this thing a month? Go high compression and add some good gas to that pump piss!
Re: How much compression is really enough? [Re: frank] #818113
10/01/10 09:06 PM
10/01/10 09:06 PM
Prospect, PA
BSB67 Online content
BSB67  Online Content
Prospect, PA
My Eddy head 508 is 10.8:1, has an intake closing point of 76* ABDC (measured at 0.006" lobe lift), has a cranking cylinder pressure of 190 psi and it is pretty close to the edge on 93 octane pump gas.
With this you can get feel for what you might be able to get away with regarding cam around this CR.
If your goal is low 12s, there is no need to get too close to the edge on CR for your 91 octane.
