Re: To gear or not to gear..3.55 or 4.11s [Re: 68 Sat] #817432
09/30/10 11:04 AM
09/30/10 11:04 AM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
Is 4.10s too much for local street cruising.
Yes. It really depends on your ability to ignore things like poor mileage and high revs on the highway. With every 120hp Honda blowing by you on the highway as you camp out in the right lane.
There is no correct gear. Everything will be a comprimise.
If you need business taken care on both ends. Launching due to a high overlap camshafts AND you like driving on the highway.
OVERDRIVE.
Re: To gear or not to gear..3.55 or 4.11s [Re: Magnum] #817433
09/30/10 11:20 AM
09/30/10 11:20 AM
P
Paul_Fancsali Offline
P
I have used on the street 4.56 gears with 29 tall tire and it is no big deal. I currently have 4.10s in one car and 3.91 in the other and 3.55s in the 3rd. I will stick with the gears. I like response and you will not get the that with 3.55s in a heavy car A body fine B body no. I switched to set of 3.55s in my heavy 73 and took them out same day too much of low end difference may go back to 4.30s that I ran for 4 years I never have a issue holding 3500 + heck it blows the cob webs out drive it 55 miles to track one way If you need ear plugs your exhaust is too loud
Re: To gear or not to gear..3.55 or 4.11s [Re: Paul_Fancsali] #817434
09/30/10 12:38 PM
09/30/10 12:38 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
I had 3.55's in my car with a lockup 904 and 27" tires and hated it. was tolerable on 55mph speed limit roads, but freeway speed limit in MI is 70, and ~3300 RPM (what it cranked along at ~70 mph) for any distance just wore me down.
I kept the gears, but added an A500, so my effective rear gear with OD is 2.45. much better.....
personally, I'd keep the rear gears you have, add a limited slip diff (I'd go with the torsen style offered by eaton, I think, if buying new), and high stall, relatively tight converter--one that will flash to ~2700-3000 RPM when you stomp on it, but not have a ton of slip at speed...
2017 Grand Cherokee Overland
