To gear or not to gear..3.55 or 4.11s
#817412
09/29/10 01:55 PM
09/29/10 01:55 PM
Posts: 683 Northern NJ
68 Sat
Northern NJ
The stats are as follows. A 440 bored .30 over,Eddy RPM heads, Intake,600cfm carb, comp cam (mild), headers, 295/55/15s ET drags..in a 1968 B Body. Currently has a 2.97 open rear...ugh
I want to take it to the track occasionally (6x per season) and cruise whenever.
Is 4.10s too much for local street cruising. I might be trying to do too much but am in a pickle.. All comments are welcome..
1963 Chrysler 300 Pace Setter Convertible 21K mile survivor
1969 Dodge Coronet 500
1956 Desoto Hemi
1955 Chrysler C300
Re: To gear or not to gear..3.55 or 4.11s
[Re: Mr.Yuck]
#817415
09/29/10 02:04 PM
09/29/10 02:04 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
Having been the route with many set ups - I would recommend for your application to go with the 3.55's. Being you will be mostly cruising, I also recommend a vac secondary carb like the 750 Holley vac. They will give the secondary usage when you need it most and not before,
Clean it, if it's Dirty. Oil it, if it Squeaks.
But: Don't fix it, if it Works!
[Re: Mr.Yuck]
#817416
09/29/10 02:07 PM
09/29/10 02:07 PM
68 Sat
Northern NJ
Cam specs
213064 Big Chrysler 1800-5500 224/224 .470/.470
1956 Desoto Hemi
1955 Chrysler C300
[Re: 2boltmain]
#817419
09/29/10 02:37 PM
09/29/10 02:37 PM
68 Sat
Northern NJ
I don't have the gears yet. My tires measure 27.8 inches tall so I am starting to understand where all this is taking me. I guess I can always upgrade to bigger gears in the future..
1956 Desoto Hemi
1955 Chrysler C300
[Re: MoparforLife]
#817421
09/29/10 02:48 PM
09/29/10 02:48 PM
Posts: 3,897 St. Louis, MO
Blues_Cuda
St. Louis, MO
4.10's are a blast around town, but if you plan to spend time on the highway you may find that you do not like them. Speaking from experience, my wife's '70 Barracuda is running 4.10's with a 295/65/15 tire...it's definitely not for a long highway drive. As an example, I would not hop in it and drive 7 hours to Columbus for the Nats. We do drive it the 25-30 miles to the track without issue. 3000rpm is 60-65 mph.
Given your relatively mild combo, I'd personally go with 3.55's and a 3310 Holley as mentioned above.
If you decide on a more aggressive cam and have a loose coverter or 4spd, run the 4.10's for loads of fun.
[Re: 68 Sat]
#817422
09/29/10 04:54 PM
09/29/10 04:54 PM
Posts: 3,122 Auburn WA
Dave_J
Auburn WA
Ok, your talking a TORQUE monster 440, not a 318 here. IMHO for a 90% street/10% strip car with loads of torque, the 3.55's should get the job done. My 78 LRT came with a 3.55 Open 9.25 and it is ok but running over 3200 RPM at 60 MPH is the pits if driving over 25 miles. I must wear ear plugs if going any farther. It is compounded by having those twin stacks right behind the head. I could not live with anything like 4.10's without a OD trans. I will be putting a set of 3.21's with a SG in a 9.25 in my LRT soon. But I also have a 3200 RPM lockup converter that I will be putting in too. Now give me a A-518 OD and I may put in some 4.56's as that will get me back below 3.55's in OD.
Retired, US ARMY 1973-1994 ASE mechanic, Electrical 1994-1997 Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter 65 Formula S Cuda 78 Little Red Express Truck 98 Buick Regal (wifes car)
[Re: Dave_J]
#817423
09/29/10 05:00 PM
09/29/10 05:00 PM
Posts: 4,825 Holland MI Ottawa
2boltmain
Holland MI Ottawa
My car with 4:10s I found "Not Fun" to drive where the speed limit was 55mph. We all know if the limit is 55 everyone is driving 60 and 60mph produced an RPM too high for me- for any distance.
Keep old mopars alive.
[Re: stumpy]
#817425
09/29/10 06:25 PM
09/29/10 06:25 PM
68 Sat
Northern NJ
Thanks Stumpy. That is real helpful. I went with the 3.55s. I'll let you guys know how it turns out...
1956 Desoto Hemi
1955 Chrysler C300
[Re: 68 Sat]
#817427
09/29/10 08:48 PM
09/29/10 08:48 PM
Posts: 4,503 NJ
440challenger
NJ
[Re: DaytonaTurbo]
#817431
09/30/10 08:13 AM
09/30/10 08:13 AM
Blues_Cuda
St. Louis, MO
I was thinking on the way in to work this morning... How many here drove Super Track Pak cars back in the day? Or to open the playing field, any make of car with 4.10 or lower gears as a main source of transportation? Other than the period when mileage was on everybody's mind, was anybody concerned about how many rpms were showing on the tach while tooling down the highway? I was born in the early 70's, so obviously I was not old enough to experience it. I'll have to ask my Dad for his feedback this weekend. He always had some sort of musclecar back in the day.
