when to run a tranny cooler #817384
09/29/10 01:19 PM
09/29/10 01:19 PM
Spring Valley ,Ca.
moparsquid Offline OP
Spring Valley ,Ca.
Im using a t/c that has been flashed to about 2800-3200 rpm .what determines when i should run a external oil cooler over the stock in rad unit.
Re: when to run a tranny cooler [Re: moparsquid] #817385
09/29/10 01:50 PM
09/29/10 01:50 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Higher stall will make more heat. if you just tool around town with that lower stall your stock cooler should be ok, but if your going to stall/flash it a lot and close together it might heat the fluid good.I would at least run a deeper pan that will hold 2 to 4 quarts more.
Re: when to run a tranny cooler [Re: moparsquid] #817386
09/29/10 02:18 PM
09/29/10 02:18 PM
morrisville, pa
skajm Offline
skajm  Offline
morrisville, pa
I think all the time. just cheap insurance for the tranny. summit sells a bunch of different stlyes. or hit the junk yards BUT FLUSH it real good. also may want to think about a remote filter that use an oil filter. if you go these route get real trans rubber line not fuel line.
Joe
Re: when to run a tranny cooler [Re: ademon] #817387
09/29/10 05:57 PM
09/29/10 05:57 PM
Spring Valley ,Ca.
Spring Valley ,Ca.
thanks I allready have a deep pan and pom. ill run a external cooler also.
Re: when to run a tranny cooler [Re: moparsquid] #817388
09/29/10 06:17 PM
09/29/10 06:17 PM
Under My Car
Mopar_Country Offline
Under My Car
Always.
Re: when to run a tranny cooler [Re: Mopar_Country] #817389
09/29/10 10:25 PM
09/29/10 10:25 PM
scratchnfotraction Offline
allways,I run a stock one for a HD truck on both of mine
like said,if used be sure to flush them good
got a PS cooler and an oil cooler on mine
tranz cooler is stock 85 truck unit,ps cooler is from a 93 DAK v-8,oil cooler is from a 88 police gran fury
have a 7 blade fan and a 3 core rad
all on my 85 truck
Re: when to run a tranny cooler [Re: moparsquid] #817390
09/29/10 10:33 PM
09/29/10 10:33 PM
RapidRobert Online content
RapidRobert  Online Content
good idea on a stock TC & I run one on everything & as said a must w your stall. Largest one you can fit in there
Re: when to run a tranny cooler [Re: RapidRobert] #817391
09/29/10 11:38 PM
09/29/10 11:38 PM
North Central Florida
E
eightlitermopar Offline
E
I always decided to run one after I completely fried my transmission. However, I have 2 (yes 2) coolers and I think I may have overdone it.
It completely bypasses the radiator but even on the hottest day, my tranny gauge (sender is in the pan) never goes about 170. On a normal day, I'm lucky to hit 140 or 150.
Now I am afraid of keeping it too cool.
eight
Mopar or no car
Re: when to run a tranny cooler [Re: eightlitermopar] #817392
09/30/10 03:17 AM
09/30/10 03:17 AM
Florida STAYcation
BeEtLeJuIcE ! Offline
The village idiot's idiot
Florida STAYcation
eight
That CAN be a problem ...toooo cool ATF will "kill" some of the stall speed.
Re: when to run a tranny cooler [Re: BeEtLeJuIcE !] #817393
09/30/10 04:14 AM
09/30/10 04:14 AM
Nampa, ID
None2Slow Offline
None2Slow  Offline
Nampa, ID
You should run the tranny lines from the 2 coolers you have and now back into the radiator. This will help get some heat back into it and also help cool your engine. I have heard the same thing about being to cool.
Re: when to run a tranny cooler [Re: None2Slow] #817394
09/30/10 09:46 AM
09/30/10 09:46 AM
Florida STAYcation
Florida STAYcation
The radiator "cooler" is also a HEATER ... in fact lots of later model trans-combos will not operate properly uNtil the ATF is up-to-temp.
The only motor-vehicle-combo I could think-of that you would not want to use a radiator cooler/heater would be a all-out race-car or a towing/RV combo.
Re: when to run a tranny cooler [Re: moparsquid] #817395
09/30/10 12:56 PM
09/30/10 12:56 PM
Locomotion Offline
Locomotion  Offline
Consider synthetic transmission fluid also!
Heat is the #1 source of problems for an automatic trans. Synthetics hold up much better against heat and potential breakdown.
Amsoil Universal trans fluid.
I've been using their Universal trans fluid in my 2004 Dodge diesel dually that I tow my race car trailer with and their SuperShift in my race car 904. My trans builder said to keep using whatever I have because it protects very well.
Car is race-only, but converter flashes between 5000 and 5400 footbraking, depending on weather and other factors, weighing 3,540+ lbs. Summertime hot-lapping in the late rounds is what concerns me the most and I have an external cooler also, but bypassing the radiator.
Re: when to run a tranny cooler [Re: Locomotion] #817396
10/01/10 10:03 AM
10/01/10 10:03 AM
New Hampshire
W
whitemtnelf Offline
whitemtnelf  Offline
W
New Hampshire
Also consider using a thermostat such as this one to keep the fluid at operating temp:
http://www.summitracing.com/parts/PRM-1070/
Re: when to run a tranny cooler [Re: whitemtnelf] #817397
10/01/10 10:25 AM
10/01/10 10:25 AM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
The ideal set-up is an oversized/large trans cooler before the "in-tank" cooler that maintains the "running-temp" of the returning fluid to the trans.
Heat is the greatest nemesis of an automatic trans.
And as mentioned, too cool is not ideal either, the fluid is not a consistent temp for operation.
Some car makers now use a thermostatic bypass to help the trans heat up its fluid quicker to running temp......something to think about.
Re: when to run a tranny cooler [Re: Locomotion] #817398
10/01/10 08:30 PM
10/01/10 08:30 PM
Spring Valley ,Ca.
Spring Valley ,Ca.
thanks i was considering a synsetic what about the cunverter do you have to drain it completely first before filling . wfat about using type f i used it before in my 63 with manual rev valve body ,was told it seals better ....?
Re: when to run a tranny cooler [Re: moparsquid] #817399
10/01/10 08:45 PM
10/01/10 08:45 PM
Under My Car
Under My Car
I don't think synthetic is going to be a problem. Run your external cooler inline with you're radiator cooler, I run mine into the rad cooler out to the external and back to trans. Type F fluid will firm up your shifts a little.
