Re: manifold leak, any one ever use Right Stuff on one?
[Re: 79machocharger]
#817321
09/29/10 11:28 AM
09/29/10 11:28 AM
Posts: 8,020 Pangaea
B5 Bee
Pangaea
Don't use Right Stuff, it's only good for 450*F. Use a thin layer of this. Many racers use it without any gasket on their headers.
#817322
09/29/10 11:35 AM
09/29/10 11:35 AM
Posts: 75,095 A Banana Republic near you.
JohnRR
I keep blowing out my manifold gaskets in the same spot where the exhaust manifold meets the head in the center section. The cars going to be torn all apart this winter and when I do I'll take the manifold in to be resurface along with the head so I wont have this issue. I was just wondering if I can use somthing like Right Stuff to seal it up with out a gasket for the time being. I might take the exhaust manifold off and have that done right now but the I think the problem is the head as I can feel some ruffness in the area where it keeps blowing out. Thanks for any help.
Your manifold is warped , big block or smallblock?
You could try the remfex gasket or just cut the center out of another gasket and put it just in the center ?
[Re: DJVCuda]
#817324
09/29/10 03:19 PM
09/29/10 03:19 PM
Posts: 4,324 St. Louis, Mo
318 Stroker
St. Louis, Mo
www.remflex.com gaskets will seal it
Solved my constantly leaking exhaust gasket problems... ![](/ubbthreads/images/graemlins/thumbs.gif)
And they can be bought alot cheaper on Amazon than from Remflex.
