Re: How to remove broken torsion bar adjustment bolt
[Re: JohnRR]
#817106
09/28/10 11:27 PM
09/28/10 11:27 PM
Challenger 1
Cincinnati, Ohio
It's not going to be easy, if at all possible, since the bolt is under tension .
I've never had it happen, so...What about torching the torsion bar in half? Will that do it?
[Re: chargers777]
#817110
09/29/10 04:53 AM
09/29/10 04:53 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
I dont have a torch but I have a plasma cutter.Could I cut the anchor off where it comes out of the control arm?I am calling the anchor the part the bolt threads into.
The problem is when you cut the anchor the torsion bar is gonna unload... Big time dangerous... If you can release the tension by separating the lower ball joint & unbolting the shock than yeah plasma the anchor, but don't try it without releasing the tension..
[Re: chargers777]
#817114
09/29/10 05:57 PM
09/29/10 05:57 PM
Posts: 9,316 SoCal
68HemiB
SoCal
The "swing the LCA down" method has been suggested already. Because I'm lazy, here's a link to a similar thread with a more verbose description of that very undertaking.
Down to just a blue car now.
