master cylinder #817057
09/28/10 11:03 PM
09/28/10 11:03 PM
Illinois
Tinman761 Offline OP
Illinois
Hello all, I'm replacing the master on the 67 coronet. I think that been part of the problem with the brakes hanging up. Question is, does anyone know what the original master might look like. I'm tryin to keep the car original looking. thanks, Joe
Re: master cylinder [Re: Tinman761] #817058
09/28/10 11:34 PM
09/28/10 11:34 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Have you or anyone ever changed the original rubber flex lines, front and rear?
Re: master cylinder [Re: A12] #817059
09/29/10 12:01 AM
09/29/10 12:01 AM
Illinois
Illinois
yes, i changed the front lines about 2 years ago, im not sure if the master is original or not
Re: master cylinder [Re: Tinman761] #817060
09/29/10 12:03 AM
09/29/10 12:03 AM
Crook County, ILL
Mastershake340 Offline
Crook County, ILL
Disc or drum?
Re: master cylinder [Re: Mastershake340] #817061
09/29/10 12:07 AM
09/29/10 12:07 AM
Illinois
Illinois
drums all around, there seems to be two different tops, how d0 i know which one is correct
Re: master cylinder [Re: A12] #817062
09/29/10 12:18 AM
09/29/10 12:18 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
it should be the early style with the bolt on lid, and dual lines..
Re: master cylinder [Re: sthemi] #817063
09/29/10 12:23 AM
09/29/10 12:23 AM
Illinois
Illinois
thats the same one that the parts manual shows, like i mentioned before , mine has a raised top. any idea why the difference? thanks for the help
Re: master cylinder [Re: Tinman761] #817064
09/29/10 12:25 AM
09/29/10 12:25 AM
Crook County, ILL
Crook County, ILL
Yours is an aftermarket replacement
Re: master cylinder [Re: Mastershake340] #817065
09/29/10 12:30 AM
09/29/10 12:30 AM
Illinois
Illinois
Thank you all very much for the info!!!! I have the answer I need, Joe
Re: master cylinder [Re: Tinman761] #817066
09/29/10 01:29 AM
09/29/10 01:29 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
With drums the brake lines will exit the master cylinder on the left or driver's side like sthemi's example. With discs the lines will exit the master cylinder on the right side.
Re: master cylinder [Re: A12] #817067
09/29/10 10:07 AM
09/29/10 10:07 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Unless it's a hemi master cylinder
