Question About Welding Sheet Metal??? #816672
09/28/10 01:50 PM
09/28/10 01:50 PM
440charger70 Offline OP
super street
super street
When welding in new sheet metal onto a car, is it necessary to completely weld in the metal, or is it fine to do a tach ever inch or two and bondo over.
Looking to do decent work here, just seeing if I am waisting my gas and wire to run the entire bead...
1970 Dodge Charger 440 (NOM) 1971 Plymouth Duster 340 (#'s Correct) 2008 Jeep Wrangler Sahara. Nice Home for sale near Tampa FL http://ruskinonline.com/docs/WimaumaHouse.htm
Re: Question About Welding Sheet Metal??? [Re: 440charger70] #816673
09/28/10 02:11 PM
09/28/10 02:11 PM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
IF you are butt welding, you should weld the entire seam.. a small section at a time, then go back after it cools off and weld more..
If you are lap welding over an offset edge or on top of the base metal, tack welds about 1 inch apart will work.
Heat build up will ruin the job.. be carefull...
Re: Question About Welding Sheet Metal??? [Re: 440charger70] #816674
09/28/10 02:27 PM
09/28/10 02:27 PM
Under My Car
Mopar_Country Offline
Under My Car
You will want to stitch it as described above, just be sure to move around so not to overheat any one particular area to avoid warping. After an area has cooled go back and add a little more weld. Patience, take your time and it will be fine.
Re: Question About Welding Sheet Metal??? [Re: Mopar_Country] #816675
09/28/10 02:33 PM
09/28/10 02:33 PM
uk
TiMopar Offline
TiMopar  Offline
uk
Also, Eastwood make a re-usable paste stuff that you can put either side of the weld to aid cooling and avoid warping. Main thing is as others suggested to take your time and keep moving...
Re: Question About Welding Sheet Metal??? [Re: TiMopar] #816676
09/28/10 07:46 PM
09/28/10 07:46 PM
Auburn WA
Dave_J Offline
Dave_J  Offline
Auburn WA
You can also get some strips of Copper. This copper strip can be shaped some and then hold it behind a hole and weld the edges around the hole up. The weld will not stick to the copper plus the copper will wick heat away some. Go slow and dont over heat the panel.
Retired, US ARMY 1973-1994
ASE mechanic, Electrical 1994-1997
Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter
65 Formula S Cuda
78 Little Red Express Truck
98 Buick Regal (wifes car)
Re: Question About Welding Sheet Metal??? [Re: Mopar_Country] #816677
09/29/10 12:49 AM
09/29/10 12:49 AM
Iowa
66Hemiwagon Offline
66Hemiwagon  Offline
Iowa
do not get in a hurry
Re: Question About Welding Sheet Metal??? [Re: 66Hemiwagon] #816678
09/29/10 09:21 AM
09/29/10 09:21 AM
Greentown Indiana
moparmxz Offline
moparmxz  Offline
Greentown Indiana
Weld the entire seam if you want it to hold.
Randy Brough 1967 440 Dart S/P 6.37 106mph best eighth 3150 lbs
Re: Question About Welding Sheet Metal??? [Re: moparmxz] #816679
09/29/10 09:45 AM
09/29/10 09:45 AM
WI. U.S.A.
DusTed74 Offline
DusTed74  Offline
WI. U.S.A.
The copper works great as a backing for filling in small holes too.
I found a small length of copper tubing and just pressed it flat. Now it can be held with a vise grip or C clamped in place.
Re: Question About Welding Sheet Metal??? [Re: moparmxz] #816680
09/29/10 09:53 AM
09/29/10 09:53 AM
WI
RestoRick Offline
RestoRick  Offline
WI
Also, if it's in an accessible area, shine light from behind to check for pinholes. Give moisture ANY place where it can get behind the filler and it WILL bubble it up!
Rick
