carter 3258S carb #816472
09/28/10 01:37 AM
09/28/10 01:37 AM
wisconsin united states
K
keith airgrabber Offline OP
Right in the Nutz!!!
K
Just bought a carter 3258S carburator from a swap meet. Bought it thinking it was close to the 3447 carb I need parts for.Thought I could swap the throttle linkage shaft from the primaries. But it is not the same. But I got the carb dirt cheap. The guy had no clue what it came from. I knew it was the front carb on the chrysler 413 dual 4-barrel. And I also found out it was factory on some Ford Cobras. What do these carbs go for if I were to sell. Any ideas? Are they as rare as my 3447?
Re: carter 3258S carb [Re: keith airgrabber] #816473
09/28/10 02:20 AM
09/28/10 02:20 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
it's a front carb for a 59-62 inline dual 4 barrel setup. Neat carbs if you have both, the linkage, and the intake. As a single it's not going to make you rich. They are in low demand and not really the best performance carb being the smaller AFB design. Still worth keeping intact rather than parting it. I don't know what you need for 3447 parts but I would look for them elsewhere before tearing up that carb. If it's throttle arms you need those are available reproduction.
Re: carter 3258S carb [Re: ScottSmith_Harms] #816474
09/28/10 02:24 AM
09/28/10 02:24 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
That's a carb that I would like to have, but I'm not familiar with the 3447, so I don't know if I have anything in my pile-o-carbs that would help. I do have the intake, but niether of the correct carbs or the linkage.......
Re: carter 3258S carb [Re: Jim_Lusk] #816475
09/28/10 10:13 AM
09/28/10 10:13 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Jim,
The 3447 is 62 and early 63 Max Wedge.Fuel inlet is on front of bowl and throttle shaft is different.
Re: carter 3258S carb [Re: 62maxwgn] #816476
09/28/10 10:14 AM
09/28/10 10:14 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
3258 and 3259 ,front carb,no choke.
Re: carter 3258S carb [Re: 62maxwgn] #816477
09/28/10 04:12 PM
09/28/10 04:12 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Jim,
The 3447 is 62 and early 63 Max Wedge.Fuel inlet is on front of bowl,no choke and throttle shaft is different.
You might find some parts on Buick AFBs and they had the fuel inlet on the front like that. Don't know about the rest of the parts.
Re: carter 3258S carb [Re: Jim_Lusk] #816478
09/28/10 04:35 PM
09/28/10 04:35 PM
sweden
cuda-sweden Offline
cuda-sweden  Offline
sweden
i think those 3258-3259 are recomended in my dc-bible for the 62 str-15 inline tunnelram/crossram,with jetting rexcomendations and so on.
