what size carb #816309
09/27/10 09:38 PM
09/27/10 09:38 PM
Cumberland County, NJ
coronetkid Offline OP
408 sbc
victor jr. intake
dart pro 1 heads
intake runner 200cc
exhaust runner 75cc
comb chamber 72cc
cam solid flat tappet .244/.252 duration
.520/.540 lift
SRP flat top pistons
comp ratio 10.5
1 3/4 hedman long tubes into x-pipe
what do you guys think?
Re: what size carb [Re: coronetkid] #816310
09/27/10 09:45 PM
09/27/10 09:45 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Holley 950
Re: what size carb [Re: ScottSmith_Harms] #816311
09/28/10 05:25 PM
09/28/10 05:25 PM
that big? really?
Re: what size carb [Re: ScottSmith_Harms] #816312
09/28/10 08:16 PM
09/28/10 08:16 PM
Central NC
gch Online content
gch  Online Content
Central NC
Gearing,stall,weight,etc would help for a race effort.Anything from a 750dp on up will work.
An 850 would probably take care of any street/strip effort.
Re: what size carb [Re: gch] #816313
09/28/10 08:25 PM
09/28/10 08:25 PM
PA
Moparzrule Offline
Moparzrule  Offline
PA
MOE had an article on big carbs/small cubes.
http://editions.amospublishing.com/MPRE/default.aspx?d=20100701
My
Own
Personal
Adrenaline
Rush
Re: what size carb [Re: ScottSmith_Harms] #816314
09/28/10 08:51 PM
09/28/10 08:51 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Holley 950
Its not 950 cfm. It has 1.375 venturi like a 750, with contoured body and 1.75 throttle bore. Throttle response of a 750, performance of an 850. Perfect for what you've got.
Re: what size carb [Re: BSB67] #816315
09/28/10 10:12 PM
09/28/10 10:12 PM
Morris County NJ
Rustydog Offline
Rustydog  Offline
Morris County NJ
General rule of thumb,
(Cubic inches X Max RPM) / 3456 = CFM
Re: what size carb [Re: Rustydog] #816316
09/28/10 10:16 PM
09/28/10 10:16 PM
Morris County NJ
Rustydog Offline
Rustydog  Offline
Morris County NJ
I'd recommend 750 cfm
mechanical secondaries
jets 72 & 82
Don't over carburate with an 850 cfm
Re: what size carb [Re: Rustydog] #816317
09/29/10 12:53 AM
09/29/10 12:53 AM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Holley 950hp
That formula is only good if you want to under carb an engine IMO. Essenstially, it's good to arrive at the smallest carb you might want to use.
Re: what size carb [Re: RobX4406] #816318
09/29/10 07:56 AM
09/29/10 07:56 AM
kentucky
superbyrd Offline
superbyrd  Offline
kentucky
i would agree on the 750 mechanical. the worst thing most people do is over carburate.....
Re: what size carb [Re: superbyrd] #816319
09/29/10 11:41 AM
09/29/10 11:41 AM
RobX4406 Offline
RobX4406  Offline
360 at 6500 says 688cfm using the formula.
Why is it that many go much faster with larger carbs and have used 1050 dominators doing so. My 360 is getting a 1050 so I must be crazy.
That formula is set up for a 1.5" pressure drop, IIRC. I don't know many that think a 1.5" drop is acceptable for a performance engine at full throttle. What adjustments have to be made to the formula for a 1", .5" or zero pressure drop? Something like a 23% increase going from 1.5" to 1.0" comes to mind.
Re: what size carb [Re: RobX4406] #816320
09/29/10 02:17 PM
09/29/10 02:17 PM
NC, USA
davenc Offline
davenc  Offline
NC, USA
A 750CFM carb will only flow around 640CFM at 1.1" (if I did my math right). At 0.75", it will only flow 520CFM.
As I understand it, the issue with lower pressure drops is getting good fuel metering. Getting the carb right under such conditions is why some carb vendors can charge a premium.
If that 360 was spinning at 6500RPM, then a 800CFM carb at 1.1" would just meet its needs (assuming 100% VE at that RPM).
