'Nother 999 trans question #816229
09/27/10 08:19 PM
09/27/10 08:19 PM
Spahn Ranch
RMCHRGR Offline OP
RMCHRGR  Offline OP
Spahn Ranch
Trying to figure out whether PK# 4028815 would be a lock up transmission. Someone has one that I might be interested in buying unless it's a lockup which I do not want.
The My Mopar trans guide lists it for a '78 Chrysler application with 360-equipped cars but does not specify lockup or not.
Thanks for the input.
- Greg
'71 Duster
'17 Ram 1500
Re: 'Nother 999 trans question [Re: RMCHRGR] #816230
09/27/10 08:23 PM
09/27/10 08:23 PM
Northwest, Ohio
360DOUG Offline
360DOUG  Offline
Northwest, Ohio
According to the direct connection chassis manual it is a lock up transmission.
Re: 'Nother 999 trans question [Re: RMCHRGR] #816231
09/27/10 08:32 PM
09/27/10 08:32 PM
if it's a '78 yes a LU. If the splines on the front input shaft are not splined out to the very tip but have a turned down (machined) section at the tip it is a LU.
Re: 'Nother 999 trans question [Re: RapidRobert] #816232
09/27/10 08:42 PM
09/27/10 08:42 PM
S.E.Ohio
Magnumguy Offline
Magnumguy  Offline
S.E.Ohio
What they all said above, and remember, some 727's were lockup as well. If you can find a donor car w/the A36 (maybe A38) towing package, that tranny is non-lockup.
Most likely it's a lockup, can be confirmed if you know what application and car it came from.
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
Re: 'Nother 999 trans question [Re: Magnumguy] #816233
09/27/10 09:03 PM
09/27/10 09:03 PM
Spahn Ranch
RMCHRGR Offline OP
RMCHRGR  Offline OP
Spahn Ranch
Thanks for the replies. Seller claims the unit is from a '77 model year 360 powered Chrysler 300.
Is there even such a car?
Based on the replies, it seems like I may have to pass on this one.
'71 Duster
'17 Ram 1500
