Gearing question, Torque or HP?? #815548
09/27/10 09:30 AM
09/27/10 09:30 AM
New Mexico
dmerc Offline OP
dmerc  Offline OP
New Mexico
When settling on the final drive ratio what should I shoot for? Peak torque or peak HP through the traps?
Re: Gearing question, Torque or HP?? [Re: dmerc] #815549
09/27/10 09:36 AM
09/27/10 09:36 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Set it so you cross the traps at 10% higher than the
peak HP rpm
Re: Gearing question, Torque or HP?? [Re: MR_P_BODY] #815550
09/27/10 11:32 AM
09/27/10 11:32 AM
gregsdart Offline
gregsdart  Offline
peak HP rpm
The only reason to vary from that would be something like a stroker with small heads where it would lay down after peak hp real quick.
Re: Gearing question, Torque or HP?? [Re: gregsdart] #815551
09/27/10 12:54 PM
09/27/10 12:54 PM
New Mexico
dmerc Offline OP
dmerc  Offline OP
New Mexico
peak HP rpm
Actually that is kind of what I have. Was built for good torque and gas mileage. Goes like hell to about 4800 RPM then just lays down. I'm leaning towards 3.73 ratio.
Re: Gearing question, Torque or HP?? [Re: dmerc] #815552
09/27/10 01:26 PM
09/27/10 01:26 PM
MR_P_BODY Offline
MR_P_BODY  Offline
peak HP rpm
Still comes down to the same thing... but your HP
number is lower
