To drill or not to drill..................... #815254
09/26/10 08:24 PM
09/26/10 08:24 PM
State of confusion
Thumperdart Offline OP
State of confusion
Just curious as to how many of you drill your dist. caps for venting and if you drill bet. each post or just on top. I used to drill a hole bet. each post but setting timing can be a "shocking" experience if you know what I mean. Thankxxxxxx
Re: To drill or not to drill..................... [Re: Thumperdart] #815255
09/26/10 08:26 PM
09/26/10 08:26 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
I don't do it..
Re: To drill or not to drill..................... [Re: VernMotor] #815256
09/26/10 08:27 PM
09/26/10 08:27 PM
State of confusion
State of confusion
Any reason?
Re: To drill or not to drill..................... [Re: VernMotor] #815257
09/26/10 08:28 PM
09/26/10 08:28 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Me either.
Re: To drill or not to drill..................... [Re: ProSport] #815258
09/26/10 08:33 PM
09/26/10 08:33 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
Cap has a vent on it..I beleve thats all it needs.. the drilling of the cap is a old trick to index the dist.I have done it in the past..no gains that I could see..unless you like geting shocked LOL
Re: To drill or not to drill..................... [Re: Thumperdart] #815259
09/26/10 08:37 PM
09/26/10 08:37 PM
Any reason?
If it doesn't miss at high RPM when hot lappng the car it ain't needed Drilling the caps was a bandaid, let the ionized air out, before they started venting the caps
Re: To drill or not to drill..................... [Re: Cab_Burge] #815260
09/26/10 08:38 PM
09/26/10 08:38 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Any reason?
Exactly...
Re: To drill or not to drill..................... [Re: Cab_Burge] #815261
09/26/10 08:40 PM
09/26/10 08:40 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
used to do it running points and an MSD - but since going electronic have not done it. It used to make setting the timing real fun! Oh and never spray WD-40 around the thing either
Re: To drill or not to drill..................... [Re: Cab_Burge] #815262
09/26/10 08:41 PM
09/26/10 08:41 PM
State of confusion
State of confusion
Thankxxx guys, guess I can go back to setting the timing w/it running instead of having to shut it down, twist the dizzy THEN check it.
Re: To drill or not to drill..................... [Re: Thumperdart] #815263
09/26/10 08:42 PM
09/26/10 08:42 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
I did
when I had my tach drive and now my msd distributer
drilled every hole inbetween the terminals
ita a air gap and no crossfiring at high rpm,s
1.39 9.85 - 137 mph
