Re: New AFCO bg shocks on the dart and a new best!!
[Re: RyanJ]
#815226
09/27/10 12:26 PM
09/27/10 12:26 PM
Posts: 2,813 Blue Ridge, VA
Plumb Wired
Blue Ridge, VA
Donald/Mike, how much you spraying (Hp wise) to run 132 Mph in the 1/8 on that setup?
Glad to see it is still in 1 piece & congrats on new best.
Ryan, this is with a 36n/28f (350hp), 5.5 psi fuel pressure, 15 degrees of timing, 4 degrees of launch retard for 1.20 seconds or so depending on the track, no fuel ring and timing mark before the bend on the ground strap. You know what a slug it was on the dyno so it likes the spray!
Big thanks to Monte Smith on the nitrous mapping!
FYI, the motor will be coming out soon for you to freshen.
RIP Monte Smith
aka: OutlawFish '98 Bickel Dodge Dakota PST
