40 spline axle ? #814916
09/26/10 01:33 PM
09/26/10 01:33 PM
Vidor Texas
O
onyxba Offline OP
onyxba  Offline OP
O
Vidor Texas
For the people running 40 spline axles are you runing the big ford bearing 3.150 are the symmetrical 3.350 bearing. If you are running the big ford have you had problems wearing bearings out? Thanks Brian W.
Re: 40 spline axle ? [Re: onyxba] #814917
09/26/10 01:38 PM
09/26/10 01:38 PM
Ohio
theclutcher Offline
theclutcher  Offline
Ohio
3.150, strip only and not enough time on that.
I know that can take a good side load after slapping the wall.
