Thread lock on axle studs?
#814793
09/26/10 10:49 AM
09/26/10 10:49 AM
Posts: 1,320 Lees Summit, MO
BrianT
Lees Summit, MO
I'm swapping out the 3 inch studs on my new Strange axles for some 2 inch ones. I need to know what if any thread lock I should put on them? Anyone know what they should be torqued to? Thanks!
Edit: These are screw in studs.
1970 Duster 340 clone
Re: Thread lock on axle studs?
[Re: BrianT]
#814796
09/26/10 06:24 PM
09/26/10 06:24 PM
Posts: 2,586 Illinois, Indiana, Louisiana
ProStDodge
I don't think the studs need to be torqued, only tightened. The stud is torqued (loaded or stretched - depending on how you want to look at it) with the lug nut. You just need to be sure there is complete thread engagement into the axle flange. For maximum hold, there should be a few threads extending out the back of flange. Since, if I remember correctly, the strange kit has ny-lock nuts on the back, there is more than enough thread through the flange. If there is no locking nut, then yes, I would use a lock-tight to secure the stud to the flange.
With 5/8" studs and my Weld Pro-Stars I use 135 ft.lbs on the lug nuts.
Scott
[Re: ProStDodge]
#814797
09/26/10 08:00 PM
09/26/10 08:00 PM
BrianT
Lees Summit, MO
Now we're gettin somewhere. I'm SURE that the new studs need to be torqued, I just don't know to what ft/lbs. I'm not sure what you mean by thread engagement. The studs are like 2 inch bolts that have to be threaded in from the back. As far as leaving threads extending from the back?!? If the stud is torqued, the head will be against the back of the flange when tight. There are no washers or nylock nuts. This is what my axles look like now. This is what I'm trying to install.
[Re: BrianT]
#814801
09/26/10 09:10 PM
09/26/10 09:10 PM
ProStDodge
OK - Those are not "studs", they are bolts. I was assuming you had actual studs, which are threaded at both ends. Sorry for the confusion.
Even with your bolts, the torque is not critical, as there is not clamping force. getting them tight should be all that is required. If you really need a number, I would say you would be safe at 75-95 ft.lbs on 5/8" bolts.
The load is imposed on the bolt from the lug nut end, which should be in the 135-ft.lb. range.
The kit I have has actual studs with nuts on the back side of the axle flange to keep the studs from backing out.
