How to seal an exhaust stud in the water jacket?
#813702
09/25/10 09:09 AM
09/25/10 09:09 AM
Posts: 1,070 Newton, KS
70B5Cuda
Newton, KS
One of the exhaust studs came out with the nut when removing a cracked exh manifold and it was in the water jacket. What is the best way to seal it when reinstalling the manifold so I don't have any leaks?
1970 Barracuda B5 6.1 Hemi/6 speed 1969 Charger survivor in R6 383/727-wrecked 12/24/18 1968 Charger in original burgundy paint "Ribeye" 1968 Charger w/ 6.1L, TR-6060, 9" 1968 Roadrunner w/ 6.1L/6 speed 2011 Dodge Ram w/ 6.7L
Re: How to seal an exhaust stud in the water jacket?
[Re: Ronnman]
#813705
09/25/10 11:11 AM
09/25/10 11:11 AM
Posts: 3,396 St. Charles, MO
wingman
Uncreative Title
Uncreative Title
St. Charles, MO
Unlike header bolts, the shoulder above the threads of the exhaust studs seal pretty well when run in tight against the block.
Just a little schmear of thread sealant is all I have ever used and not had a problem.
1969 Dodge Coronet Super Bee 383 A4 1970 Plymouth Road Runner 440 FC7 (sold)
[Re: 70B5Cuda]
#813707
09/25/10 11:49 AM
09/25/10 11:49 AM
Posts: 9,336 South-Central (Sebring), FL
Commando1
No more will I take redo the bolt fiasco (that Mopar dreamed up ![](/ubbthreads/images/graemlins/eyes.gif) ) AFTER the engine installation... I anti-seize it, then Loctite Copper, then teflon tape it for good measure. Sounds like a witches brew that can't work, but it does - dam if I know why
