Main cap orientation-help me remember! #813688
09/25/10 03:17 AM
09/25/10 03:17 AM
California
P
polkat Offline OP
mopar addict
polkat  Offline OP
mopar addict
P
California
440 was apart when I bought it. The main caps are numbered 1 to 5 as usual, but there is no arrow to orientate them. I seem to remember that the bearing shell tabs should be on the same side for both rods and mains. Is that right?
Re: Main cap orientation-help me remember! [Re: polkat] #813689
09/25/10 09:04 AM
09/25/10 09:04 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
yes the taps block and cap go to the same side.
Re: Main cap orientation-help me remember! [Re: Dodgem] #813690
09/25/10 11:12 AM
09/25/10 11:12 AM
Carson City, NV
babarracuda Offline
babarracuda  Offline
Carson City, NV
The rear main can only go on one way. Use it for the example.
Re: Main cap orientation-help me remember! [Re: Dodgem] #813691
09/25/10 12:03 PM
09/25/10 12:03 PM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
Now everyone's wondering: Did I absolutely check for that the last time I rebuilt a block.
Re: Main cap orientation-help me remember! [Re: Commando1] #813692
09/25/10 01:51 PM
09/25/10 01:51 PM
Tustin, CA
P
pishta Offline
pishta  Offline
P
Tustin, CA
they are numbered, just make the numbers read correctly in relation to the number orientation of the main seal cap. IIRC, the numbers face correctly if you are looking at the inverted block on a stand with the cam gear on your left.
Re: Main cap orientation-help me remember! [Re: Commando1] #813693
09/25/10 01:53 PM
09/25/10 01:53 PM
Pa
Hot 340 Online content
Hot 340  Online Content
Pa
Bolts wont thread if cap on backwards. Still. always remember on rods and mains, lock to lock.
Re: Main cap orientation-help me remember! [Re: Commando1] #813694
09/25/10 06:23 PM
09/25/10 06:23 PM
Indiana
Gabby63 Offline
Gabby63  Offline
Indiana
Boy I needed that laugh , thanks ! Gary
