How much pressure is needed in cooling system?
#813573
09/24/10 10:57 PM
09/24/10 10:57 PM
Posts: 17,924 Akron, Ohio
ProSport
Akron, Ohio
After my scare last friday with the freeze plug blowing out we removed the radiator cap that was 16 or more pounds and installed a 7 pound cap. I noticed Summit sells zero and 4 pound caps.
Re: How much pressure is needed in cooling system?
[Re: ProSport]
#813574
09/24/10 11:18 PM
09/24/10 11:18 PM
Posts: 52,972 Romeo MI
MR_P_BODY
You dont need any pressure UNLESS you have a over heating issue
[Re: Bob_Coomer]
#813576
09/24/10 11:53 PM
09/24/10 11:53 PM
ProSport
Akron, Ohio
Thanks, I think I'll try the 4 pound cap. The car doesn't run hot, and I'm not sure why that freeze plug blew out, but I'm thinking less pressure in there won't hurt.
[Re: ProSport]
#813577
09/25/10 12:03 AM
09/25/10 12:03 AM
Quicktree
I bet pressure had nothing to do with it. something flexing or plugs not installed deep enough.
[Re: ProSport]
#813578
09/25/10 12:13 AM
09/25/10 12:13 AM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
Bob, I feel its a good idea to use a higher psi cap to help prevent the water from boiling. Once it boils, the pressure can sky rocket. If your having heating issues that are causing the pressures to rise enough to blow out a freeze plug, lowering the cap pressure will allow your current system to boil over sooner. Witch will disperse that excess presure into your overflow reseveware, if it can handle all of it. IMO, stick with the higher pressure cap and fix any over heating or loose freeze plug issues. mike Reducing radiator cap pressure is just asking for boil over problems on our hot running race/street cars. Extra cap pressure rating is a good thing IMO. mike
[Re: Sport440]
#813579
09/25/10 12:15 AM
09/25/10 12:15 AM
Quicktree
I run a 16lb cap
[Re: ProSport]
#813580
09/25/10 12:40 AM
09/25/10 12:40 AM
Posts: 3,502 SOUTH JERSEY
HEMIFRED
SOUTH JERSEY
When I run Evans Coolant it doesn't boil until 370 degrees so only zero cap
home of the Sox and Martin Hemi Duster
[Re: Sport440]
#813581
09/25/10 12:57 AM
09/25/10 12:57 AM
Posts: 4,210 New York
polyspheric
New York
Run the highest cap pressure your radiator and gaskets will stand. The first place water boils is inside the head, at the exhaust seat and spark plug - even if your gauge still shows 180°. When this happens, the steam formed at the metal surface prevents water from touching the metal, and it just gets hotter. The steam can't transfer any heat - it's not dense enough. Result: the engine knocks. Increasing the pressure raises the local boiling point a lot. How is this different from just running 50/50 anti-freeze to raise the boiling point? 50% antifreeze only transfers heat at 1/2 the rate of water.
Boffin Emeritus
[Re: Chad Bittle]
#813583
09/25/10 01:42 AM
09/25/10 01:42 AM
ProSport
Akron, Ohio
Interesting stuff, my car doesn't run hot. When the freeze plug blew out it was only at 170 degrees or less. I just figured that whatever happened may be prevented by a lower pressure cap. That freeze plug shot out like a cannon, made a loud BANG that I heard over the engine at full song. By the looks of the plug, it was more than likely installed wrong.
[Re: jcc]
#813585
09/25/10 07:25 AM
09/25/10 07:25 AM
Posts: 6,295 U.S.
moparniac
U.S.
Bob I had a freeze plug blow out on me one time also in my challanger leaving a garage hammering on it down the street! I now have screw in freeze plugs though I have heard of people dying from that going down the track from that happening! old archived pic!
Mopar Performance
[Re: ProSport]
#813586
09/25/10 08:19 AM
09/25/10 08:19 AM
Posts: 976 ontario canada
mac56
ontario canada
If a freeze plug shoots out like a cannon I would have to think there is something else going on. I run a 22 lb. cap for the reason stated early about steam forming around center exhaust ports.
[Re: mac56]
#813587
09/25/10 10:01 AM
09/25/10 10:01 AM
Posts: 146 michigan
tonycpe
michigan
Do most engine builders stake the freeze plugs?
Old Fogey Racing Ltd.
[Re: tonycpe]
#813588
09/25/10 12:25 PM
09/25/10 12:25 PM
Posts: 1,532 off the grid
340B5
off the grid
As said above, no pressure is needed. Every one lb. pressure increase raises the boiling point 2 degrees. Evans coolant?
Yeah, it's got a smallblock.
[Re: ProSport]
#813590
09/25/10 12:47 PM
09/25/10 12:47 PM
Posts: 5,895 Florida
Locomotion
A blown head gasket can often cause overheating. But even if yours was not, it wouldn't hurt to go through the tests for a blown head gasket including watching for bubbles in a cool or warm, full radiator while running with the cap off.
Get much water in your overflow bottle?
[Re: Locomotion]
#813591
09/25/10 06:22 PM
09/25/10 06:22 PM
Posts: 7,506 Az
Crizila
Az
Evans Coolant? Anyone have info on it? Make up, NHRA legal, where to buy? Thanks.
Fastest 300
[Re: Crizila]
#813592
09/25/10 07:25 PM
09/25/10 07:25 PM
polyspheric
New York
Evans has an interesting idea (can't boil at any temp found in the water system), but it's only about 65-70% as effective at removing heat from the jacket surfaces. If you still have local boiling-induced knock at 250°F (15 lb. cap, pure water) Evans will help with the boiling but the engine will operate at higher temperature unless you increase the water transfer rate, radiator size, air volume through the core, etc. It's also about 10 × as viscous as water, so the pumping load is higher (even with no cap, there's pressure inside the engine).
Summary: if you have a cooling problem Evans won't help since the engine temp will go up. The "tests" showing the Evans is cooler than the water it replaced as it exits the engine is simple: it's absorbing less heat. If you can't control knock with water and a pressure cap, it will fix that (but the temp will go up).
There's also a cost problem: Water is free, plus a pressure cap, and you can get more anywhere. Evans is over $100 to fill (but permanent), you should still run a cap (it smells bad).
Boffin Emeritus
