BB water pump question
#813423
09/24/10 07:09 PM
09/24/10 07:09 PM
Posts: 105 Florida, USA.
john e
Florida, USA.
I've been away from big blocks for quite a while and my memory is a bit fuzzy. I'm putting together a basically stock '68 HP-383 that will be going in a non-AC '69 Coronet with highway gearing. I have both pumps, a 6-bladed impeller and a 8-bladed one. I know one is for AC and the other non-AC, but I don't remember which is which. All the modern listings don't specify a difference anymore. When I ran this same engine almost 20 years ago, it had the 8-bladed pump and ran just fine in the Florida heat, never getting over about 170degrees even in traffic. So which pump should I go with?
Street racing is a mystery to most people, but I've got it figured out. If it blows up with a single 4, go dual quads. If that goes, inject it. And fix it fast.
Re: BB water pump question
[Re: Andrewh]
#813427
09/24/10 10:19 PM
09/24/10 10:19 PM
RapidRobert
use the 8 vane pump & weld on an anticavitation plate on the back side of the vanes between them & the pump whereas on a SB the plate would be welded on the other side facing the timing cover
[Re: pishta]
#813430
09/25/10 01:34 AM
09/25/10 01:34 AM
Posts: 3,319 Chicago Burbs
sthemi
Chicago Burbs
The 8 blade deal is the correct and hard to find one. The 6 blade is a universal replacement and came about in the late 70s when most cars came with A/C. I run the 160 t stat and the engine is a lot happier with today's fuel..., than the warmer ones..
[Re: Andrewh]
#813432
09/25/10 03:52 AM
09/25/10 03:52 AM
Posts: 1,805 ky hills
thehemikid
ky hills
lol, both wrong. 6 vane is the a/c.
the a/c uses a smaller pulley so it spins faster.
8 vane is the non-a/c pump. uses a bigger pulley and spins slower.
They are afraid the 8 vane with the smaller pulley will cause cavatation and cause damage.
...Dug out my original 68 shop manual, & it reads in the 7-14 SPECIFICATIONS that the standard is 4.38"-8, & the A/C is 3.67"-6, So, sounds like the 6 blade is correct. They may have done something different, but the book say's 6. They also show & list some 10 blade impellers.
