Correct Code/Formula 68 Roadrunner Hood - Flat Black #813282
09/24/10 02:08 PM
09/24/10 02:08 PM
San Antonio, Tx
bulletpruf Offline OP
San Antonio, Tx
Fellas -
Have a 68 Roadrunner with the flat black Performance Hood Treatment. Hood is about to be painted. Paint guy uses PPG products. Is there a code or formula paint that he should be using?
Thanks,
Scott
Please Check Out My YouTube Channel for Vintage Musclecar and Truck Rescues and Builds -- https://www.youtube.com/@THEBULLETPROOFGARAGE/videos
Re: Correct Code/Formula 68 Roadrunner Hood - Flat Black [Re: bulletpruf] #813283
09/24/10 02:15 PM
09/24/10 02:15 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
The orignal stuff no longer exists, but ppg has a newer version that people have been using instead.
https://board.moparts.org/ubbthreads/show...part=1&vc=1
Re: Correct Code/Formula 68 Roadrunner Hood - Flat Black [Re: Neil] #813284
09/24/10 03:49 PM
09/24/10 03:49 PM
San Antonio, Tx
San Antonio, Tx
Thanks!
Scott
Re: Correct Code/Formula 68 Roadrunner Hood - Flat Black [Re: bulletpruf] #813285
09/25/10 12:19 AM
09/25/10 12:19 AM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
Scott,
We used Hot Rod Black for my hood. It may not be 100% correct but it looks really nice.
Re: Correct Code/Formula 68 Roadrunner Hood - Flat Black [Re: Neil] #813286
09/25/10 01:42 AM
09/25/10 01:42 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
I just did my 68 RR hood in DCC 9355.
That is single stage concept.
I had a pint mixed and didnt use it all.
Two normal coats and a third coat using a lot of reducer...to blend in the surface texture...
Re: Correct Code/Formula 68 Roadrunner Hood - Flat Black [Re: sthemi] #813287
09/25/10 01:44 AM
09/25/10 01:44 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
Another..
Re: Correct Code/Formula 68 Roadrunner Hood - Flat Black [Re: sthemi] #813288
09/25/10 10:16 AM
09/25/10 10:16 AM
SE Pa.
LimeliteAero Offline
SE Pa.
Another..
any more pics of that car?
