Re: change main and rod bearings???
[Re: wmwalden]
#812618
09/23/10 02:22 PM
09/23/10 02:22 PM
Posts: 9,336 South-Central (Sebring), FL
Commando1
...change main and rod bearings...
I will be installing a new rear main seal as well.
Shoot, with all that work alone, I'd do it right and pull the engine and do a mild rebuild. I mean, what are you saving? Certainly not aggravation.
[Re: wmwalden]
#812621
09/23/10 08:55 PM
09/23/10 08:55 PM
Posts: 276 Temecula, Ca.
zzyzxpat
Temecula, Ca.
You need to pull the pan to check the rear band. Did you change it? Did you loosen the adjuster when you built the trans? If not, it is probably fine, otherwise, you should check it.
" The last official act of any goverment, is to loot the treasury" George Washington
