Alternator not charging batteries?? #812450
09/23/10 09:59 AM
09/23/10 09:59 AM
South Shore MA
67GTMIKE Offline OP
67GTMIKE  Offline OP
South Shore MA
Big block, elect water pump and fans, duel batteries in trunk, running in series.
I had a single wire 90 amp alternator installed and it is not doing crap. Tester shows it putting out amps but, it does not appear to be charging batts. My Volts gauge showed about 14 volts, after driving 15 minutes, it was down to 8 volts.
Any suggestions, not used to having duel batteries, am I missing something?
Re: Alternator not charging batteries?? [Re: 67GTMIKE] #812451
09/23/10 10:35 AM
09/23/10 10:35 AM
Marlboro, NY, USA
Rick_Ehrenberg Offline
Marlboro, NY, USA
These dueling dual batteries that are in series...they are each 6V batteries?
Rick
Re: Alternator not charging batteries?? [Re: Rick_Ehrenberg] #812452
09/23/10 05:49 PM
09/23/10 05:49 PM
COLLINGWOOD, ONT
71_deputy Offline
71_deputy  Offline
COLLINGWOOD, ONT
also check at each battery the voltage to them- maybe the 14 volts is not getting to them!
Re: Alternator not charging batteries?? [Re: 67GTMIKE] #812453
09/23/10 06:31 PM
09/23/10 06:31 PM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
two 12 volt batteries in series is like one 24 volt...why are you running this configuration ??
People upgrade the alternator to support electric fans and such....you have a 12 volt output supporting a 24 volt system...again....why ??
Re: Alternator not charging batteries?? [Re: terzmo] #812454
09/23/10 10:09 PM
09/23/10 10:09 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
As mentioned (2) 12V batteries in series equals 24V, instead the batteries should be in parallel for double current but @ 12V. The alternator assuming it is a standard Mopar one can only charge 12V batteries.
Just my $0.02...
Re: Alternator not charging batteries?? [Re: Sinitro] #812455
09/23/10 10:18 PM
09/23/10 10:18 PM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
two 12 volt batteries in paraleel will only deliver 6 volts
Re: Alternator not charging batteries?? [Re: terzmo] #812456
09/23/10 10:30 PM
09/23/10 10:30 PM
Chilly Northern, Minn.
71 Charger R/T Offline
What?!
Re: Alternator not charging batteries?? [Re: terzmo] #812457
09/23/10 10:58 PM
09/23/10 10:58 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Math, spelling, whatever
Don't be the exception.
Re: Alternator not charging batteries?? [Re: Supercuda] #812458
09/23/10 11:05 PM
09/23/10 11:05 PM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
paralell...happy now
Re: Alternator not charging batteries?? [Re: terzmo] #812459
09/23/10 11:07 PM
09/23/10 11:07 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Ummm, no....2 batteries in parallel will still have 12 volts.
Re: Alternator not charging batteries?? [Re: OzHemi] #812460
09/23/10 11:11 PM
09/23/10 11:11 PM
Mena Arkansas
DTM_Motorsports Offline
Mena Arkansas
well if they are fighting each other (dueling)
then maybe they are using all their energy..
Dual, not Duel ...
Re: Alternator not charging batteries?? [Re: DTM_Motorsports] #812461
09/23/10 11:13 PM
09/23/10 11:13 PM
67GTMIKE please chime in
Re: Alternator not charging batteries?? [Re: terzmo] #812462
09/24/10 12:07 AM
09/24/10 12:07 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Fail
It's parallel
and two batteries in parallel are still the same voltage but increased current capacity.
Re: Alternator not charging batteries?? [Re: Supercuda] #812463
09/24/10 12:34 AM
09/24/10 12:34 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I hope you guys are just joking around or this is just sad
Two 12-Volt Batteries in series is 24-Volts, double the voltage, but same current rating as one one battery.
Two 12-Volt Batteries in parallel is still 12-Volts, but twice the current rating.
If your running an alternator you usually only need one battery to get the car started then the alternator takes over to power the car and recharge the battery. The dual batteries in parallel gives extra current capacity to maintain the 12-volts longer when there is no alternator to supply power.
Dual batteries are used in Diesel trucks because the starter motor operates on 24-volts, where the batteries are temporarily connected in series, but charged individually through a battery isolator.
HD non-diesel trucks that have dual batteries will charge the batteries through an isolator, but the truck basically is operation on just one battery with the second one in reserve for things like wenching.
Re: Alternator not charging batteries?? [Re: terzmo] #812464
09/24/10 10:36 AM
09/24/10 10:36 AM
Andrewh Online content
Andrewh  Online Content
voltage does not work that way.
Resistance in a circuit works that way.
Re: Alternator not charging batteries?? [Re: Andrewh] #812465
09/24/10 01:24 PM
09/24/10 01:24 PM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
yepper....My mistake on that part...but he's still running a 24 volt source in a 12 volt system
Re: Alternator not charging batteries?? [Re: terzmo] #812466
09/24/10 02:40 PM
09/24/10 02:40 PM
well that depends on how it is actually wired.
Re: Alternator not charging batteries?? [Re: Andrewh] #812467
09/27/10 10:51 AM
09/27/10 10:51 AM
South Shore MA
67GTMIKE Offline OP
67GTMIKE  Offline OP
South Shore MA
Thanks for all the replies..
The 2 batts are in series and shows just under 14v on my volt gauge when charged, car is setup with large fans, elect water pump, stereo system, ect.. so I assume that is why the extra battery was installed.
I installed a alternator, so I would not have to charge the batts manualy anymore. For whatever reason the vbelt was defective.
I picked up another and everything is working perfectly now. I thought I had done something wrong but it was just the belt.
Thanks again-
