Re: How hard will it be to repair this rust? [Re: Commando1] #812365
09/23/10 02:25 PM
09/23/10 02:25 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Don't get in to much of a hurry the right two door will come along..
Like this one for example...
http://cgi.ebay.com/ebaymotors/ws/eBayIS...#ht_1109wt_1166
Funny, I PMed that to Kevin earlier.. Looks surprisingly good/solid for a car in Jersey.. Hopefully a local member can look it over..
Re: How hard will it be to repair this rust? [Re: 1_WILD_RT] #812366
09/23/10 02:36 PM
09/23/10 02:36 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
I wouldn't be afraid to patch it in (weld in metal).
You could also replace that section with one from another car, it doesn't have to be an Imperial.
Just a similar shaped windshield header from a Chrysler would probably work.
On a side note, have you seen this car?
73 2 door Imperial on Racing Junk
Re: How hard will it be to repair this rust? [Re: feets] #812367
09/23/10 02:44 PM
09/23/10 02:44 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
I'm concerned with where the water went after leaking through the roof. It had to run down the A pillars. Chances are, they're toast too. No doubt the floors would hold it and get nasty as well.
Yea it's probably even worse than that. I bet you can stick your fingers right through to the inside of the car. In addition to the a pillars and floor you can also expect the dash, firewall, and plenum to be ugly. Even the steering column might be unusable. For sure the sunvisors, carpet and upholstery are toast.
Keep looking for a better one. That one is going to need way too much and whole bunch of
Re: How hard will it be to repair this rust? [Re: GomangoCuda] #812368
09/23/10 03:08 PM
09/23/10 03:08 PM
New Hampshire
W
whitemtnelf Offline
whitemtnelf  Offline
W
New Hampshire
I second GoMangoCuda's opinion. I'm working on a car that didn't look half as bad as your pics and found out the rust was twice as bad as I had thought. You'll have to cut back pretty far to get to steel that you can weld to. Because that is a structural member you're probably looking at something like 18g steel with some tight bends. I've been working 18g steel to fix my rocker panels and its noticeably harder to work with than the 20g I've been using for body panels. This is my first attempt to do panel forming and it takes a lot of practice so be prepared to have to make the piece a couple of times before you get it right.
Re: How hard will it be to repair this rust? [Re: whitemtnelf] #812369
09/23/10 03:32 PM
09/23/10 03:32 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
I'm gonna pass on the gold car unless the guy is giving it away.
The racing junk car is a rust bucket. There are holes in the rockers where the A pillar joins in. All the body seams are rusty. It's the car owned by the guy who accused me of being a scammer. He later spent an hour on the phone with me and sent a truck load of pics.
The Ebay car looks nice but it becomes a question of how high will it go? I'm really strapped for cash.
Naturally, having money means you have no time.
Having time means you don't have money.
I've gotta be cheap. I'd like to find a car with a few options and black interior. The coupes are what I really want but I'd take a crew cab too.
- Stu Harmon
Re: How hard will it be to repair this rust? [Re: feets] #812370
09/23/10 05:35 PM
09/23/10 05:35 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
FEETS, take a look at this thread
http://www.jalopyjournal.com/forum/showthread.php?t=337728&showall=1
If that doesn't scare you, maybe you can do it too.
Re: How hard will it be to repair this rust? [Re: RodStRace] #812371
09/23/10 06:30 PM
09/23/10 06:30 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Some really nice work there!
Re: How hard will it be to repair this rust? [Re: OzHemi] #812372
09/23/10 07:54 PM
09/23/10 07:54 PM
If it's rusted in that area what do the "normal" rust areas like quarters, trunk floor, and trunk floor extensions look like?! Back window? Lower front fenders?
Re: How hard will it be to repair this rust? #812373
09/23/10 09:56 PM
09/23/10 09:56 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
The other rusty areas aren't bad. The driver's quarter has some rust but it hasn't broken through more than an inch from the wheel opening. The car is in decent shape with the exception of that roof.
- Stu Harmon
Re: How hard will it be to repair this rust? [Re: Commando1] #812374
09/23/10 10:45 PM
09/23/10 10:45 PM
Columbia Station, Ohio
69RTSE Offline
69RTSE  Offline
Wow! Did you guys see that window sticker?!?! $7300 in 1969! Thats alot of green!
Re: How hard will it be to repair this rust? [Re: 69RTSE] #812375
09/23/10 10:53 PM
09/23/10 10:53 PM
NC
Tommy383 Offline
Tommy383  Offline
NC
i had the same rust along the roof of my 70 rr....ended up buying a roof from a 69, and having it welded up....couldnt tell it was different without looking behind the headliner.....i think i paid 150 for the roof...and a couple hundred for the bodywork...
BUT i dont know how hard it would be to find a parts car like that one...
Re: How hard will it be to repair this rust? [Re: Tommy383] #812376
09/24/10 12:32 AM
09/24/10 12:32 AM
saint paul mn.
johnzgarage Offline
johnzgarage  Offline
saint paul mn.
That's a not that hard to fix. That's just a pimple, compaired to the "cancer" us northern guy's fix. Just take your time ,It will come out great.
