Aluminum Radiator 63 B-body #811087
09/21/10 08:01 PM
09/21/10 08:01 PM
Indiana
Gabby63 Offline OP
Gabby63  Offline OP
Indiana
Hello all , looking for a radiator for my 63 Fury , I race and would like to update to a aluminum , still using stock one . Any recommendations ? Seen one on ebay that was a direct bolt in ( appears to be very well built ) no trans fittings tho , I use a separate coolr for trans . what have you guys & gals used ? apprectiate any info you have , thanks Gary
Re: Aluminum Radiator 63 B-body [Re: Gabby63] #811088
09/21/10 08:45 PM
09/21/10 08:45 PM
tboomer Offline
tboomer  Offline
Welcome aboard,Gabby!! In my 64 330 sedan,I used a Be Cool from Summit...Local welder did the brackets...I have around 200.00 in it...
Re: Aluminum Radiator 63 B-body [Re: tboomer] #811089
09/21/10 09:02 PM
09/21/10 09:02 PM
Indiana
Gabby63 Offline OP
Gabby63  Offline OP
Indiana
Thanks will look into that , I seen a Champion on ebay but the water pump ( or lower hose nipple ) outlet is on the passenger side , I need it on the drivers side , have an aluminum pump housing and do not want to change it . They claim they cannot change it due to they do not make them just sell them . Gary
Re: Aluminum Radiator 63 B-body [Re: Gabby63] #811090
09/21/10 09:19 PM
09/21/10 09:19 PM
gtx69 Offline
super gas
gtx69  Offline
super gas
Check the ads on here.Guy on here sells the same rad with the outlet on the side you need.Do a search on for sell ads
Re: Aluminum Radiator 63 B-body [Re: gtx69] #811091
09/21/10 10:25 PM
09/21/10 10:25 PM
Indiana
Gabby63 Offline OP
Gabby63  Offline OP
Indiana
Thanks , kind of new here so what am I looking for ?
Re: Aluminum Radiator 63 B-body [Re: gtx69] #811092
09/21/10 10:31 PM
09/21/10 10:31 PM
Andrewh Offline
Andrewh  Offline
got one for my 65 from 4 seconds flat.
dual pass, so you need to pick both inlet and outlet would be on the same side.
Re: Aluminum Radiator 63 B-body [Re: Andrewh] #811093
09/21/10 10:35 PM
09/21/10 10:35 PM
gtx69 Offline
super gas
gtx69  Offline
super gas
champion radiator
Re: Aluminum Radiator 63 B-body [Re: gtx69] #811094
09/23/10 03:32 AM
09/23/10 03:32 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Bought this from Mancini for my 63 Sport Fury. It is an Afco rad and cost me $349. Ron
Re: Aluminum Radiator 63 B-body [Re: 383man] #811095
09/23/10 08:55 PM
09/23/10 08:55 PM
Indiana
Gabby63 Offline OP
Gabby63  Offline OP
Indiana
Thanks for the info Ron , looks like it fits very well . How well does it cool ? Mine is a drag car so I start from the gage being at zero but warm , by the time I get through staging lanes & burnout and make a pass I'm pushin 160 degrees . So I'm hoping this will help tremendously . I run eight mile , 6.50's 103 mph . Gary
Looks like you have a nice set-up ! Do you know where I can get the zip ties that go through the radiator for my fan ?
Re: Aluminum Radiator 63 B-body [Re: Gabby63] #811096
09/24/10 12:21 AM
09/24/10 12:21 AM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
Wizard Cooling 26" in my car works great.
Re: Aluminum Radiator 63 B-body [Re: Azzkikrcuda] #811097
09/24/10 01:11 AM
09/24/10 01:11 AM
Indiana
Gabby63 Offline OP
Gabby63  Offline OP
Indiana
Well I ordered a Champion radiator from Craig , another member here . He had all the info , had great service & is a super guy to talk to ( and is a distributer for Champion ) for 230.00 shipped to my door . Soon as I get it I will let everyone know . Gary
Re: Aluminum Radiator 63 B-body [Re: Gabby63] #811098
09/25/10 04:16 AM
09/25/10 04:16 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
It cools just fine. Course mine is a street car and I drive it to the track. On hot summer days it is about 180 when I get to the track. It never goes over 180 even when racing and I only need to turn the electric fan on when stuck in traffic for a bit of time. But it sounds like you got a great deal on the rad you bought. Good luck with it. Ron
Re: Aluminum Radiator 63 B-body [Re: 383man] #811099
09/25/10 05:53 PM
09/25/10 05:53 PM
Indiana
Gabby63 Offline OP
Gabby63  Offline OP
Indiana
Thanks , glad to hear that its performance is what was expected . Gary
