Re: Started My Build For Next Years Drag Week ...UPDATE
[Re: aarcudaden]
#810835
01/27/11 12:48 AM
01/27/11 12:48 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Im really looking forward to seeing pics of this thing when its starting to come together
LOL... so am I... all I seem to be doing is cutting more on it.... now it seems that I have turned the corner is it should look like progress from here on in
[Re: MR_P_BODY]
#810836
03/06/11 12:52 AM
03/06/11 12:52 AM
MR_P_BODY
I bought another Rampage today for some parts but its nicer than mine... I was giving it thought about cutting up the parts one but I'll stick with the original one and just pull the parts I need... glad to be back so I can get back to work on it... got to set the engine back in to check a few mock up points on the steering... I did quite a few drawings of different things on it while on vacation
[Re: 1Fast340]
#810838
03/06/11 11:17 AM
03/06/11 11:17 AM
MR_P_BODY
btt this is an intresting build for sure:) just a noviceQuestion since i never built a complete car from basicly nothing, why taking the engine in and out for mockup, when you could just leave it in its mounts leving it in lace would seem like a much easier way
hey i know all about that part about making drawing when being away all the best ideas are always on my mind when im not even close to the car
There isnt any mounts in the car at this time... I need to check so steering clearance on the rack to see if it will clear the front of the crank and pulley plus the engine just gets in the way
[Re: 1Fast340]
#810840
03/06/11 12:22 PM
03/06/11 12:22 PM
MR_P_BODY
thanks there is no way to learn like learning from someone who does it
I'll get some pics at a later time so you can see the close areas
[Re: MR_P_BODY]
#810841
04/09/11 03:42 PM
04/09/11 03:42 PM
MR_P_BODY
I got the front end just about done(still need to weld) but it looks pretty decent and I checked all the movements and everything looks good... I started to do some welding today but I need to cut 1 more tube and get it into place before I can burn it together on the front.... but I ordered up a couple more hole saws and they wont be here till Monday
[Re: MR_P_BODY]
#810843
04/09/11 05:43 PM
04/09/11 05:43 PM
Posts: 4,087 Shelby Twp. Mi
HardcoreB
Shelby Twp. Mi
Looks great Mike! What do you need? I may have something handy.
[Re: HardcoreB]
#810845
04/09/11 07:01 PM
04/09/11 07:01 PM
MR_P_BODY
1 5/8" hole saw with 1/2" hole for the arbor... I ordered 2 the other day but they wont be here till Monday
[Re: MR_P_BODY]
#810847
04/10/11 12:11 AM
04/10/11 12:11 AM
MR_P_BODY
Sean... dont worry about it... I'll spend tomorrow cleaning in the shop... a bomb went off in there... the other day I spent about 5 hours working on my bothers VW heads.., doing some mill work on them... but first I had to tram in the head(had it off for repairs)... so I need to clean out there... so that will be tomorrows job
[Re: Labratt]
#810849
04/10/11 01:09 AM
04/10/11 01:09 AM
MR_P_BODY
Lookin' good,Mike! I might just stop by for a visit..and help out..if you need a hand! I'll give ya' a call Monday to see what's shakin'!
I'll be here... thats where I always am
[Re: MR_P_BODY]
#810850
04/17/11 01:12 PM
04/17/11 01:12 PM
MR_P_BODY
I set it on the ground today with the front in place, I can go 1" lower in the front but I dont know if I will..... but this is where I am today... a few pics
[Re: MR_P_BODY]
#810853
04/17/11 01:20 PM
04/17/11 01:20 PM
MR_P_BODY
last... I was just seeing if I wanted it lower or not today so I can set the rear height... I still have a oil pan and trans pan that are some what low and still need exhaust under it... I believe if I can keep the exhaust up tight I can have 4" of clearance
