Re: What are the fastest SB mopar stockers ( with carbs )
[Re: 5343stk]
#810336
09/24/10 01:25 AM
09/24/10 01:25 AM
Posts: 3,505 DFW
mr_340
DFW
Are they running the "X" heads in Stock, or the 308 heads?
Floyd Lippencott IV
[Re: 5343stk]
#810338
09/24/10 10:25 AM
09/24/10 10:25 AM
Posts: 5,048 Atlanta Indiana
Dave Watt
Atlanta Indiana
Speaking from a little experience, Brad Van Lant is the best in the country in regards to small block mopars.
I have won F/SA at Indy the last two years with his power under the hood. Without his knowledge and help it wouldn't have been possible.
James, to run 10.67 @ 124 with a 1973 Plymouth Duster 340 in F/SA is flying. Quite an accomplishment.
[Re: Dave Watt]
#810339
09/24/10 11:12 AM
09/24/10 11:12 AM
Posts: 411 Big Island ,VA
JC Childress
Big Island ,VA
I have talked to Brad VanLant, Bub Whitaker, and Parsons & Myers. They have all been very,very nice and helpful to me. I am excited about this. I didnt realize that Brad himself had a car. This seems like a really neat combo. It should be fun and not nearly as expensive as some ( I didnt say it would be cheap ). The reason I asked if anyone had any X-heads, is that all three of the engine builders I mentioned told me that would be my best choice. Thanks so much to everyone for your help.
J.C. Childress
(434) 665-9541
[Re: S/ST 3040]
#810342
09/24/10 12:14 PM
09/24/10 12:14 PM
JC Childress
Big Island ,VA
what are the casting #'s on the J and X heads ?
J.C. Childress
(434) 665-9541
[Re: JC Childress]
#810343
09/24/10 12:23 PM
09/24/10 12:23 PM
Posts: 4,595 On the south side of Nowhere
S/ST 3040
2531894 (X) 3418915 (J,U,O)
I didn't know Stock Eliminator allowed heads from different years but, I don't keep up with Stocker rules.
[Re: S/ST 3040]
#810344
09/24/10 12:58 PM
09/24/10 12:58 PM
Posts: 5,895 Florida
Locomotion
They allow some "superceded" heads including 576 which are like 308's without the exhaust hole - only available over-the-counter at one time. Just gotta check the rules for specifics.
[Re: S/ST 3040]
#810345
09/24/10 01:14 PM
09/24/10 01:14 PM
Posts: 3,060 Western New York
sixpackbee
Western New York
On a budget get small valve 915's and open them up to 2.02 and they are almost as good.
1959 Bugeye Sprite 1967 Charger Black L code 1967 Coronet R/T Convert Green 440 auto bought from original owner 1968 Charger R/T Bronze 440 4 spd console AM/FM 1969 Super Bee WM21H B5 A40 D21 N96 1969 Barracuda Formula S 340 Convert pilot car 1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85 1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96 1970 Road Runner RM21N B3 V1X D13 1971 MG Midget 1971 Road Runner RM23H GW3, A57 1972 Road Runner RM23P FY1, D21
[Re: sixpackbee]
#810346
09/24/10 01:27 PM
09/24/10 01:27 PM
JC Childress
Big Island ,VA
On a budget is me exactly.
What really sucks is that I had the car setup for IHRA Top Stock, which means that the leaf springs are under the frame rails and now have to be moved back to factory location, the front suspension is stock but has rod ends now and will have to be put back to factory specs and the wheel wells have a 2 inch wide strip added in the middle to widen them and that will have to be put back like factory. I would just get another car but this one has new quarters and all the body work done and tons of chrome moly cage, all done by Wisecarver.
J.C. Childress
(434) 665-9541
[Re: Locomotion]
#810347
09/24/10 01:35 PM
09/24/10 01:35 PM
S/ST 3040
I know they allow them in SS. 308/576 has much better exhaust port. (Not that it matters in SS)
[Re: rryan5429]
#810349
09/24/10 03:21 PM
09/24/10 03:21 PM
JC Childress
Big Island ,VA
Jamie, can you PM me your number ? I'd like to talk to you about running stock if you dont mind, if you dont want to, I understand.
J.C. Childress
(434) 665-9541
[Re: rryan5429]
#810350
09/24/10 03:50 PM
09/24/10 03:50 PM
Posts: 10 MN
5343stk
MN
Rick,
Against better judgement, I'm going to BIR for the last Stock / Superstock race this weekend. Want to test a couple things on my wife's car before the snow flies.
I should have planned better and been ready for the Pierre race. Sounds like a good time. Maybe next year. Good luck
James Findell
5343 Stock
10.67 @ 124
[Re: JC Childress]
#810351
09/24/10 04:00 PM
09/24/10 04:00 PM
Posts: 608 TN
1DGEMAN
TN
If you intend to run a 70 or 71 340 the 894 heads are best and NHRA just fixed the port volumes so they reflect the true as cast numbers. Chuck Beach has a killer high comprssion AVS combination. Jerry Davis in Texas is very good with high and low compression 340's.In my opinion the low compression 340 with a 4sp is the best NHRA combination in regards to running under the index. The next best is a 340 6pack 4sp but you don't have an e body. Don't be afraid to run a 4sp combo it can be done cheaper than a tricked out auto set up.
Real Men shift for themselves
[Re: 1DGEMAN]
#810352
09/24/10 04:20 PM
09/24/10 04:20 PM
JC Childress
Big Island ,VA
This car is a factory 340, 3 speed car, and in due time it will definitely have a 4 speed G-force more than likely, maybe a Jericho. If I just get it going and use a mild 904 that will be a start, the stick tranny can come in due time.
I like the 71 hi-comp combo. Maybe not the best as far as how far under the index, but I want a combo with the fastest ET. Just my preference.
Whats gotta be done to my 70 Duster to make it a 71 ?
J.C. Childress
(434) 665-9541
[Re: S/ST 3040]
#810354
09/24/10 04:39 PM
09/24/10 04:39 PM
JC Childress
Big Island ,VA
Thats all ? Dang, you can buy them new. Thats awesome.
J.C. Childress
(434) 665-9541
