1968 Fury Disc Brake Swap from a 1975 Newport #810027
09/21/10 06:03 AM
09/21/10 06:03 AM
Germany
1964Polara Offline OP
Germany
Facing dilemma of a 1968 Fury III with Power Brakes but Drums on all 4 corners I'm looking to upgrade to a Disc Brake Setup with lots of stopping power.
Scarebird & SSBC Setup seems to be unsificient Braking power for german Autobahn with a 2,76 rear...
Following this article
http://www.moparaction.com/Tech/archive/disc-main.html
it shall be possible to swap the complete Disc Brakes from a 1973 C-Body....but can I use also some from a 1975 Newport donor car which I have access to?
Re: 1968 Fury Disc Brake Swap from a 1975 Newport [Re: 1964Polara] #810028
09/21/10 08:08 AM
09/21/10 08:08 AM
Andrewh Offline
Andrewh  Offline
The spindles and such won't work from a 75.
About the only thing that might be usable is the booster and master, but then you won't be able to down shift from drive into 2 or 1 if you have a column shift car.
Re: 1968 Fury Disc Brake Swap from a 1975 Newport [Re: Andrewh] #810029
09/21/10 10:26 AM
09/21/10 10:26 AM
Iron Station, NC
furygt Offline
furygt  Offline
Iron Station, NC
You need the disc brake set up from a '70 - '73 C Body to do this swap. The '73 set up is preferred by many but only because new rotors are less expensive than for the '70 - '72 rotors, however the '70 - '72 rotors have come down in price. There are other aftermarket kits out there. You may want to do some seaching or posting on www.cbodydrydock.com
Bill
Re: 1968 Fury Disc Brake Swap from a 1975 Newport [Re: furygt] #810030
09/21/10 12:51 PM
09/21/10 12:51 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Re: 1968 Fury Disc Brake Swap from a 1975 Newport [Re: Andrewh] #810031
09/21/10 03:20 PM
09/21/10 03:20 PM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
What's different in the design of lets say, a 74-75 spindle, and a 73 and earlier spindle.
In what way are they different, and why won't they work?
I would like to know, as people always ask about this swap, and i don't know the answer to the spindle question.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: 1968 Fury Disc Brake Swap from a 1975 Newport [Re: hemi71x] #810032
09/21/10 03:43 PM
09/21/10 03:43 PM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
Saying the "spindle" is different may be misleading to you. It is actually called the steering knuckle.
It's a completely different design in how it is attached the the U&L control arms, tie rod end, and how the disc brake (called the "slider" type) calipers are attached. Two totally different animals.
Re: 1968 Fury Disc Brake Swap from a 1975 Newport [Re: Commando1] #810033
09/21/10 05:36 PM
09/21/10 05:36 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
And don't be tempted to use the cheaper 73 rotors on the cheaper 69-72 spindles. The bearings and seals are different. Don't start thinking about how to make spacer collars and such, either.
Brake parts are cheap, buy the factory engineered system and be safe.
Re: 1968 Fury Disc Brake Swap from a 1975 Newport [Re: Fury Fan] #810034
09/21/10 10:20 PM
09/21/10 10:20 PM
Andrewh Offline
Andrewh  Offline
there was however a person that found that late model van spindles, the ones that use the 73 rotors, turned out to bolt up too. but I don't have the exact details on that.
Re: 1968 Fury Disc Brake Swap from a 1975 Newport [Re: Andrewh] #810035
09/22/10 01:13 AM
09/22/10 01:13 AM
Thigh-Gap Junction
@#$%&*! Offline
New user name, Same old jerk!
@#$%&*!  Offline
Thigh-Gap Junction
I guess that would be me, but there are other issues to deal with that make it a hard swap. One thing is that the '74-up C's/trucks used a larger upper ball joint than the earlier C's. The '74 C's and trucks also used a screw-in type lower ball joint that moves the lower attach point of the knuckle outward about 1/2". The nice thing about the swap is the big calipers, my '67 New Yorker stopped as well as the Honda Accord hatchback I used to drive around, and that's saying something.
Re: 1968 Fury Disc Brake Swap from a 1975 Newport [Re: @#$%&*!] #810036
09/22/10 07:35 AM
09/22/10 07:35 AM
Germany
Germany
Hmm lets say I would have a complete 1974 Chrysler Town & Country with 440cui...... May I swap the full braking system including Upper & Lower Control Arms? Anybody tried this?
Re: 1968 Fury Disc Brake Swap from a 1975 Newport [Re: 1964Polara] #810037
09/22/10 08:51 AM
09/22/10 08:51 AM
Commando1 Offline
Commando1  Offline
Can't say I have ever heard of anyone that insane.
Doesn't it get to a point where all the fabrication outweigh the benefits? That's a lot of work.
I had a '66 Fury where I chose to completely rebuild 100% of the manual drum system. Would stop on a dime plus a penny. Close enough for all of my type of driving.
Re: 1968 Fury Disc Brake Swap from a 1975 Newport [Re: Commando1] #810038
09/23/10 03:26 AM
09/23/10 03:26 AM
Germany
Germany
Never had a closer look at a 74 C-Body so maybe you're right if there is too much fabrication I wasn't aware of. The 74 donor car would offer also a nice 440, 727 and 8,75 axle at a decent price...
Re: 1968 Fury Disc Brake Swap from a 1975 Newport [Re: 1964Polara] #810039
09/23/10 08:44 AM
09/23/10 08:44 AM
Commando1 Offline
Commando1  Offline
9.25
Re: 1968 Fury Disc Brake Swap from a 1975 Newport [Re: Commando1] #810040
09/23/10 10:08 AM
09/23/10 10:08 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
If the pick up points on the 74 frame are the same as the 68 it would be just a matter of swapping old control arms for new. No fab involved. So has anybody actually compared the 2 frames to see if a 74 control arm will fit a 68?
Kevin
Re: 1968 Fury Disc Brake Swap from a 1975 Newport [Re: Twostick] #810041
09/23/10 10:13 AM
09/23/10 10:13 AM
St. John's Newfoundland
440newport Offline
440newport  Offline
Kevin
I doubt they would fit. 65-73 uses cam bolts on the UCA to adjust them, while 74-78 has a shaft through the UCA that is slotted in the K frame to adjust it like an F/M/J body. 2 totally different setups.
Re: 1968 Fury Disc Brake Swap from a 1975 Newport [Re: 440newport] #810042
09/23/10 10:21 AM
09/23/10 10:21 AM
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
It was a thought.
Kevin
Re: 1968 Fury Disc Brake Swap from a 1975 Newport [Re: Twostick] #810043
09/23/10 10:32 AM
09/23/10 10:32 AM
Marlboro, NY, USA
Rick_Ehrenberg Offline
Marlboro, NY, USA
Here's spec. comparisons for the various C-body discs, factory and Scarebird (from the M.A. article).
Note that any larger diameter rotors would require a wheel size increase.
Rick E.
Re: 1968 Fury Disc Brake Swap from a 1975 Newport [Re: Rick_Ehrenberg] #810044
09/23/10 10:35 AM
09/23/10 10:35 AM
Puttin' on the foil in Charles...
not_a_charger Offline
Mr. Big Shot Moparts Moderator
What brake booster would work? From what I understand, the booster from a 4 wheel drum car won't cut it once a disc swap is done.
Earning every penny of that moderator paycheck.
DBAP
Re: 1968 Fury Disc Brake Swap from a 1975 Newport [Re: not_a_charger] #810045
09/23/10 11:23 AM
09/23/10 11:23 AM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
Correct, discs run at higher pressure and a drum-brake booster isn't sufficient. Reportedly it will deceptively work for normal driving, but be inadequate for a hard stop (which is believable).
Which booster to use depends on the car. For instance, the large-diameter flat booster that I have seen on 71-73 Cs will interfere with column-shift linkage on a 68 (it will prevent the linkage from hitting 1st). My 2 conversions have been manual disc and PB but 4-speed, so I have no further info.
Also, anyone reading & planning should be aware that, unlike other Mopars, in a C-body the pedal and bracketry are different between PB and MB. Pedal setup must be correct!
Re: 1968 Fury Disc Brake Swap from a 1975 Newport [Re: Fury Fan] #810046
09/23/10 11:36 AM
09/23/10 11:36 AM
I've been talking to another Moparts member about buying a car from him (66 Fury wagon), but I can't find anyone who has the correct booster. There's one listed on Ebay that says it fits disc/drum setups "except field installed." I'm not sure what that means...maybe converted from 4 wheel drums, as opposed to factory installed disc/drum? I emailed them, but have yet to get a reply.
DBAP
