Master Cylinder Install??????? #809084
09/20/10 11:40 AM
09/20/10 11:40 AM
okla.
O
okie Offline OP
okie  Offline OP
O
okla.
70 RR manuel brakes. What is the trick to getting the top inside nut back on it? I like to have never got it off and getting it back on is going to be harder. What are some tricks to it other than dropping the steering collumn? Thanks Again Ronnie
Re: Master Cylinder Install??????? [Re: okie] #809085
09/20/10 12:13 PM
09/20/10 12:13 PM
Have not done one but might use a long 3/8 extension w a swivel socket on the end and put some tape on the socket U joint so it'll kind of stay straight but can still swivel & some tape on the inside of the socket to hold the nut in the socket & see if you can angle the whole shebang up there & get the nut started on the stud
Re: Master Cylinder Install??????? [Re: RapidRobert] #809086
09/20/10 12:24 PM
09/20/10 12:24 PM
Maryland, USA,
satgtx Offline
satgtx  Offline
Maryland, USA,
use 1/4 stuff with long extension/swivel/ piece of cake/
Re: Master Cylinder Install??????? [Re: satgtx] #809087
09/21/10 09:33 AM
09/21/10 09:33 AM
Maryland
cudaboone Offline
cudaboone  Offline
Maryland
I agree. done it. no big deal.
