Could someone tell me what this works out to?? #808842
09/20/10 12:27 AM
09/20/10 12:27 AM
Illinois
moparmattkos Offline OP
mopar addict
mopar addict
Illinois
I was thinking about this piston for a forged replacement for a 400bb standard stroke ,standard length rods. Can anyone tell me what the compression ratio would be with these and 75cc heads??
http://cgi.ebay.com/ebaymotors/Wiseco-63...sQ5fAccessories
www.sikosracing.net Heads up Drag racing
Re: Could someone tell me what this works out to?? [Re: moparmattkos] #808843
09/20/10 12:42 AM
09/20/10 12:42 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
You do realize that auction is for a single piston, they only have two in stock & there are R&L hand versions of those pistons
Re: Could someone tell me what this works out to?? [Re: 1_WILD_RT] #808844
09/20/10 12:48 AM
09/20/10 12:48 AM
Illinois
mopar addict
mopar addict
Illinois
Yes I know. I have found a set of these cheap. I think i could make them work for a .035 overbore 400 but i didnt know if i would have to have any milled off the top of the piston. I can get a set of these new for 100.
Re: Could someone tell me what this works out to?? [Re: moparmattkos] #808845
09/20/10 12:56 AM
09/20/10 12:56 AM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Re: Could someone tell me what this works out to?? [Re: moparmattkos] #808846
09/20/10 01:00 AM
09/20/10 01:00 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Well with a stroke of 3.38 divided in half is 1.69... a rod length of 6.358 & a C/H of 2.06 you get a combo height of 10.108 & the deck height spec of 9.98 you have .128 above deck to account for... A thick head gasket, an open chamber head & likely some milling on the dome... Is it worth it, you decide...
Re: Could someone tell me what this works out to?? [Re: WILD BILL] #808847
09/20/10 01:00 AM
09/20/10 01:00 AM
Illinois
mopar addict
mopar addict
Illinois
Bill I have this calculator also but with this one i cant put in the compression height of the piston or the deck height. So I dont think it will be very accurate for me.
Re: Could someone tell me what this works out to?? [Re: moparmattkos] #808848
09/20/10 01:22 AM
09/20/10 01:22 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
That piston has a 2.060" compression height for a 440 RB block. In a 400 'B' block it will be 0.128" above the deck. I don't know if the piston can be milled that much, and you would still need valve pockets. Also, the top ring is going to be very close to the top of the deck.
Re: Could someone tell me what this works out to?? [Re: moparmattkos] #808849
09/20/10 01:30 AM
09/20/10 01:30 AM
Illinois
mopar addict
mopar addict
Illinois
So if this is right then this piston will be - .072 in the hole before decking the block right?
Bore Blck Comp height 73cc
232453 4.375 10.699 1.858 10.1
Dome Vol Gram weight
-28.9 710 grams
What would compression ratio on this be with a 75cc head and a .20 head gasket with surfacing .010 off the block????
Re: Could someone tell me what this works out to?? [Re: 451Mopar] #808850
09/20/10 01:30 AM
09/20/10 01:30 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
I think the ring would be ok, if you use an open chamber head which typically are .100 deep.. You'd need to chamfer the edges of the piston & cut maybe .030 off the dome..
On the other hand thats a good 440 piston & if you decide you can't use it I'd be interested..
Re: Could someone tell me what this works out to?? [Re: moparmattkos] #808851
09/20/10 01:32 AM
09/20/10 01:32 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
-28.9 710 grams
Are we looking at a different piston or?
Re: Could someone tell me what this works out to?? [Re: 1_WILD_RT] #808852
09/20/10 01:45 AM
09/20/10 01:45 AM
Illinois
mopar addict
mopar addict
Illinois
Yes I have a option on these 2 different sets of pistons. Im thinking the second other one could work out better.
Re: Could someone tell me what this works out to?? [Re: moparmattkos] #808853
09/20/10 01:49 AM
09/20/10 01:49 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
A c/h of 1.858 will leave you .074 in the hole.. Not real good either..
Re: Could someone tell me what this works out to?? [Re: 1_WILD_RT] #808854
09/20/10 01:52 AM
09/20/10 01:52 AM
Illinois
mopar addict
mopar addict
Illinois
Oh and I forgot to mention my compression goal is about
8.5 to 1 compression. Boosted set up
Re: Could someone tell me what this works out to?? [Re: moparmattkos] #808855
09/20/10 01:58 AM
09/20/10 01:58 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Are there valve reliefs? Without reliefs, with a .021 gasket your around 9.4-1... With a .039 gasket & 4cc valve reliefs your down to 8.75-1 so that set is pretty workable for what you want..
Re: Could someone tell me what this works out to?? [Re: 1_WILD_RT] #808856
09/20/10 02:12 AM
09/20/10 02:12 AM
Illinois
mopar addict
mopar addict
Illinois
no reliefs it is a dish with a -28.9 cc dish
Re: Could someone tell me what this works out to?? [Re: moparmattkos] #808857
09/20/10 02:19 AM
09/20/10 02:19 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Back to a .021 head gasket & the C/R drops to 7.52
