how to get dipstick tube out of 99 dodge ram 5.2 litre #808250
09/19/10 06:21 PM
09/19/10 06:21 PM
mi
don b Offline OP
mopar addict
don b  Offline OP
mopar addict
mi
due to a bonehead mistake i broke the pull handle off of my oil dipstick and only way i can get broken part out of the tube is to take tube out of where it goes into the oil pan any help thanks
Re: how to get dipstick tube out of 99 dodge ram 5.2 litre [Re: don b] #808251
09/19/10 06:31 PM
09/19/10 06:31 PM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
...how far down the tube is it now?
Re: how to get dipstick tube out of 99 dodge ram 5.2 litre [Re: thehemikid] #808252
09/19/10 06:47 PM
09/19/10 06:47 PM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
...What I was getting at is, I was wondering if one of those (don't know its proper name) long reach 3 finger grippers that has a body like a choke cable, that could "maybe" grip hard enough to pull it out.
...I looked over at snap-on and didnt find but didnt know its proper name either.
Re: how to get dipstick tube out of 99 dodge ram 5.2 litre [Re: thehemikid] #808253
09/19/10 06:51 PM
09/19/10 06:51 PM
mi
don b Offline OP
mopar addict
don b  Offline OP
mopar addict
mi
about 2" thanks no it is broke with a little of the yellow hard plastic on it, i thought about trying to jb weld a piece of plastic coat hanger on it and try to pull it out that way
Re: how to get dipstick tube out of 99 dodge ram 5.2 litre [Re: don b] #808254
09/19/10 07:58 PM
09/19/10 07:58 PM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
...Have you tried a needle nose pliers or needle nose vice grip's would be better.
Re: how to get dipstick tube out of 99 dodge ram 5.2 litre [Re: don b] #808255
09/19/10 08:02 PM
09/19/10 08:02 PM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
...Will the little bit of yellow hard plastic hinder a needle nose from being able to clamp on to the steel part of the dip stick.
Re: how to get dipstick tube out of 99 dodge ram 5.2 litre [Re: don b] #808256
09/19/10 08:09 PM
09/19/10 08:09 PM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
...Can you make a (small diameter wire) wire loop to go down below the yellow piece of plastic that's left and pull it out,(depending on how good the yellow piece is still clamped to the stick.
