How do you adjust the camber on a '66 b body? #807994
09/19/10 12:32 PM
09/19/10 12:32 PM
Garland, Texas
1badmopar Offline OP
Garland, Texas
Just finsihed installing Firm Feel tubular UCAs on my '66 Belv. I need to rough in the camber so I can take the car and have it aligned. What is the proper way to adjust the camber? Currently the wheels are close at the top and spread out at the bottom.
Thanks!
1966 Plymouth Belvedere
520" RB w/ Indy 440-1 Heads
FiTech Fuel Injection
TKO 600 conversion
[img]https://flic.kr/p/2j1ejsK[/img]
Re: How do you adjust the camber on a '66 b body? [Re: 1badmopar] #807995
09/19/10 06:11 PM
09/19/10 06:11 PM
Garland, Texas
Garland, Texas
Got it figured out! Loosen the pivot / ecentric bolt nut, turn the ecentric bolt head (which forces the ecentric washers to turn) until the desired caster is acheived, then tighten the ecentric nut to lock it in place.
Im now back on the road!
Thanks.
TKO 600 conversion
