Re: Best and Safest Way to Remove Paint for Resto
[Re: RestoreCuda]
#807886
09/19/10 11:34 AM
09/19/10 11:34 AM
Posts: 222 Canfield,Ohio,USA
gassy66
Canfield,Ohio,USA
Get Yourself a low speed circular buffer(not an ocillating one) like Body Shops use for buffing,a Pad that takes 8" stick on 36 grit discs,and grind off all the paint without attacking the metal under the paint..If You have a good Air Compressor,You then sand blast the Car using no more than 140 lbs air pressure and a fine grit of sand... ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: gtx6970]
#807890
09/19/10 12:07 PM
09/19/10 12:07 PM
Posts: 1,355 maine
LO23
maine
[Re: RestoreCuda]
#807893
09/19/10 02:02 PM
09/19/10 02:02 PM
Posts: 2,938 California
1970mopar
California
If I were to use chemical stripper who makes a good product?
AIRCRAFT STRIPPER is the best (thats a name brand)
I would definately look into plastic media blasting and/or Soda blasting -
Consider that you'll spend quite alot of time and material (stripper and sand paper) to completely remove all the paint off your cars body (not to mention the hazardous waste that's left over).
Having it properly blasted is generally "cheaper" (as in easier for you with less hassle.) Most places will also Epoxy Prime right after blasting giving you a ready to start on project that's clean.
Just remember All methods have +'s and -'s. Weigh your options before you decide
[Re: RestoreCuda]
#807895
09/19/10 03:15 PM
09/19/10 03:15 PM
Posts: 5,949 British Columbia
chrisf
British Columbia
blast it. save the toxic mess for somebody else. here is a youtube vid with me on my demon using soda. there are a couple videos of it. cuda i did for a friend. soda w/ crushed glass on the floors and underhood. demon
[Re: gassy66]
#807896
09/19/10 03:22 PM
09/19/10 03:22 PM
Challenger 1
Cincinnati, Ohio
Holly Cow!! 140psi....?
If your using that much psi, you don't have the volume you need.
I blast at no more than 80-90 PSI max. Plastic I blast at 40 PSI.
IMO Blasting is best, plastic on the outter panels, something more aggressive for the bottem and rusty areas.
In order to blast the car, it must be totally stripped. If that's not possible then you shouldn't blast, soda or other wise IMO.
[Re: RestoreCuda]
#807897
09/19/10 03:42 PM
09/19/10 03:42 PM
Posts: 11,854 Georgetown Ontario Canada
anlauto
I just had this car done last week... It was 100% soda blasted inside and out, top to bottom. Then in the real rusty spots it was sand blasted. Finished off with a nice completely covering coat of epoxy primer.
I don't have time for a toxic mess of scrapping old paint, beside you can't get in the nooks and crannys very well.
CHECK OUT MY NEW WEB SITE !
[Re: DoctorDiff]
#807900
09/19/10 04:50 PM
09/19/10 04:50 PM
Posts: 8,526 Tenn.
jrwoodjoe
Tenn.
If you can afford to have it media blasted, then that (IMHO) is the best method.
Joe
65 Barracuda 70 Challenger
[Re: RestoreCuda]
#807901
09/20/10 10:14 AM
09/20/10 10:14 AM
Posts: 3,060 Western New York
sixpackbee
Western New York
Best way. Chemical dunk then e coat dunk. Very expansive though. Next best. Chemical by hand. Then very little blasting on needed areas, hard to reach areas and corrosion. Next for me is soda. While plastic does a good job it will be falling out of the body for years. You can not get it all out of the blind spots. At least plastic does not absorb moisture in tight places like sand does.
1959 Bugeye Sprite 1967 Charger Black L code 1967 Coronet R/T Convert Green 440 auto bought from original owner 1968 Charger R/T Bronze 440 4 spd console AM/FM 1969 Super Bee WM21H B5 A40 D21 N96 1969 Barracuda Formula S 340 Convert pilot car 1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85 1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96 1970 Road Runner RM21N B3 V1X D13 1971 MG Midget 1971 Road Runner RM23H GW3, A57 1972 Road Runner RM23P FY1, D21
