Re: 98 360 Stall problem Fuel starved? Help.
[Re: 67Mopar]
#80559
06/27/08 06:42 PM
06/27/08 06:42 PM
distributor pick up and/or crank sensor. both very common.if you get me your vin I can get you some part numbers. pick up 56028143 list 55.45 auto trans crank sensor 56027870 98.50 list stick trans crank sensor 56027871 98.50 list special discount for Massmopar members!
[Re: 67Mopar]
#80563
06/30/08 10:36 AM
06/30/08 10:36 AM
Posts: 2,111 Bowie, MD
Reggie
Bowie, MD
I wonder if you have a blown intake manifold plenum cover gasket. Is it using oil? Hughes sells a reinforcement kit for the problem.
[Re: Reggie]
#80564
06/30/08 12:54 PM
06/30/08 12:54 PM
Posts: 5,852 Hudson Mass
67Mopar
Hudson Mass
Ruled out that one but because of the lack of oil usage
[Re: 67Mopar]
#80565
06/30/08 01:16 PM
06/30/08 01:16 PM
Posts: 75,087 A Banana Republic near you.
JohnRR
thats not completely true
i would give moparts bob your VIN and have him see if it was done under warranty .
as far as your brakes , its a 98 2500 , the brakes just plain blow on that model year truck , if the booster was bad you would have a very hard to push peddle , is this the case ?
[Re: NITROUSN]
#80567
06/30/08 01:57 PM
06/30/08 01:57 PM
67Mopar
Hudson Mass
Bad battery....
Its not the best for sure but Id like to hear more.
Thanks all.
[Re: 67Mopar]
#80568
06/30/08 03:38 PM
06/30/08 03:38 PM
Posts: 18,426 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
Bad battery....
Thanks all.
If the battery is weak it will cause issues. The computer loses its adaptive memory if the voltage drops to low esp while cranking.
