ring gap prefferences please #805201
09/18/10 08:27 PM
09/18/10 08:27 PM
glendora, ca.
Deepockets Offline OP
glendora, ca.
just want to know your gaps and if you would vary from top grove to second grove. 4.500 bore carburated drag engine. je says .0045 per inch of bore. i just want to know if you have reasons for going more or less? thanks
Re: ring gap prefferences please [Re: Deepockets] #805202
09/18/10 09:35 PM
09/18/10 09:35 PM
NC
440Jim Offline
440Jim  Offline
NC
My 2-cents
0.022" Top
0.024" 2nd
A few reasons for variation:
Nitrous
Blower
Turbo
Street
Bore size
Injected alcohol
Big power vs moderate power
Piston material/ring pack location (hypereutectic)
Re: ring gap prefferences please [Re: 440Jim] #805203
09/18/10 11:19 PM
09/18/10 11:19 PM
My 2-cents
0.022" Top
0.024" 2nd
Nitrous
Blower
Turbo
Street
Bore size
Injected alcohol
I just finished gapping the rings in my 527 race gas bracket motor(12.7 to 1 Comp. Ratio), I set the top rings at .022 and the second rings at .024 to .026 at the rear of the motor(after getting to agaressive on the ring filer on the first two second rings) It is always way better to have .003 to big on the end gap than .0003 to small Been there done that
