power steering pump #804932
09/18/10 05:57 PM
09/18/10 05:57 PM
sweden
1Fast340 Offline OP
1Fast340  Offline OP
sweden
any sugestions on a good powersteeringpump for a 73 duster with a smallblock
dont need to be coorect in any way just something that works and is fairly easy to make some custombrackets for,reason is this is for a blown smallblock with eddy heads and im sick of my old stock mismatched brackets that wont fit anyway now that im puting a electric waterpump on the engine and will make a new custom pulley on the crank anyway and the current pump leaks alitle and is pretty worn out with alot of endplay on the axle..
Re: power steering pump [Re: 1Fast340] #804933
09/18/10 08:46 PM
09/18/10 08:46 PM
IMGTX Offline
IMGTX  Offline
The factory Saginaw's are easy to get and find. GM Ford Mopar Etc. Just abotu everyone used them.
Some years and cars have remote reservoirs which may help.
The pressure valve is in the back where the Pressure hose connects so you can probably use the factory valve with mixed combination of pumps, housings/reservoirs & drives from other vehicles. Hope it helps.
Re: power steering pump [Re: IMGTX] #804934
09/19/10 11:29 AM
09/19/10 11:29 AM
sweden
1Fast340 Offline OP
1Fast340  Offline OP
sweden
thanks
