LA 318 valve train problem! I need help!!
#804527
09/18/10 04:12 AM
09/18/10 04:12 AM
Posts: 164 mesa arizona
moturbopar
mesa arizona
Hi all I recently picked up a 69 barracuda. with a warmed over 318. When I got it I was told it was a solid lifter cammed 318. It sounded like one, but come to find out its a hydraulic cam. The noise is coming from no preload on the lifters, And 4 lifters have lost the plunger retaining clips! The heads look new, the cam looks new, pushrods are new, and the rockers look new. The pushrods measure 7.495" which looks to be close to stock. There is almost .020" between the vave and the rocker. I am new to these small block mopars and dont know what would cause this, other than something not being the right size or something being messed up! How much play are the Stock non adjustable rocker arms supposed to have on the shaft (up and down movement)? the rocker holes dont look to be perfectly round kinda egg shaped and this makes the arms a sloppy fit on the shaft. Is this normal or could this be my problem? Maybe the cam has a smaller base circle and I need loger pushrods? Thanks in advance!! ![](/ubbthreads/images/graemlins/smilie_help.gif)
Re: LA 318 valve train problem! I need help!!
[Re: moturbopar]
#804528
09/18/10 09:03 AM
09/18/10 09:03 AM
Posts: 11,543 chicagoland,usa
buildanother
chicagoland,usa
If you're sure the lifters are hydraulic, I would start with a set of new rocker arms, on good shafts that aren't trashed-galled up. Normally the preload is pretty deep, even on most aftermarket cams. I wonder if your eng has too short replacement pushrods. If the intake is off, you can easily see how much the plunger in the lifters clears the clips, and make sure you have each cam lobe on base circle, one at a time to check the depth of plungers.
[Re: MoparforLife]
#804531
09/18/10 12:09 PM
09/18/10 12:09 PM
moturbopar
mesa arizona
Thanks guys. After seeing the lifters are popping apart, I am not going to run this thing, until I figure out what the problem is. The shafts look new no galling, but Im picking up a set of new stock rockers and shaft, and going to get a set of stock low mile pushrods and see how they do. Othe than that, the only things it could be, is small base circle cam, too thick of head gasket, or the valves are shorter in the head, right??? Maybe these could be fixed with longer pushrods, or should I just start saving up for some adjustable rockers and pushrods?
[Re: MoparforLife]
#804534
09/18/10 03:10 PM
09/18/10 03:10 PM
Challenger 1
Cincinnati, Ohio
The rocker shaft holes in the rocker arms are always a bunch bigger than the shaft. Why?? I have no idea but they always seem to be that way.
Because there worn out...?
[Re: Challenger 1]
#804536
09/21/10 07:17 AM
09/21/10 07:17 AM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
Wrong answer. even new they are way larger. BB the same way. To Op. If you get the 273 rockers don't bother getting the 273 push rods. They won't work with hydraulic lifters. They will be way to long. You will need push rods for hydraulic lifters and adjustable rockers.
[Re: moturbopar]
#804538
09/21/10 10:35 PM
09/21/10 10:35 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
both cams are still aweful big...I'd probably look at a lunati voodoo 60402 if it were me....has less duration, but more lift than the cams you listed.
[Re: moturbopar]
#804544
09/27/10 04:11 PM
09/27/10 04:11 PM
MoparforLife
Upper Midwest
Well I went and looked at some new hd replacemnt mopar rockers and they are the same ones that I have, the holes are egg shaped just like these. I am starting to think it might be the head, with the valve set at the wrong height. Hopefully set of stock adjustable rocker arms will work.
Like i said that is the nature of the beast to have over sized holes in the rockers. The tops never touch anyway, the pressure is on the flat surface on the bottom. Put in some new lifters in the holes where the clips are missing . Lube them like you would on a new cam. They have to break in to the camshaft. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: moturbopar]
#804546
01/19/11 02:40 AM
01/19/11 02:40 AM
Posts: 2,275 Desert Tracker
HYPER8oSoNic
Desert Tracker
It's called "splash lubrication". As long as oil comes through the pushrod and in the passages of the rocker shafts at all operating rpms, the valvetrain stays lubed. Lack of oil at the valvetrain causes wear on the rocker shafts, arms, and valve guides. Big problems!! Most of it will start at the lifters, so keep the oil clean (changed on schedule) and use good quality oil and filters. ![](/ubbthreads/images/graemlins/2245452-furysmiley.gif)
"Stupidity is Ignorance on Steroids" "Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
