Page 14 of 19 1 2 12 13 14 15 16 18 19
Re: 514 on the dyno [Re: HardcoreB] #804432
08/13/13 11:29 PM
08/13/13 11:29 PM
AndyF Offline OP
AndyF  Offline OP
Nice results Andy. I wonder if you would compare the 440-3 (not 3x) with a 2" spacer with some mild blending everywhere.
I don't own a 440-3 at the moment. I will try a 440-3X next time I line up some dyno time. This engine hasn't really liked the -3X in the past but maybe now it is making enough power to use the 3X size. The 3X probably needs to be port matched to even come close to the Super Victor, not sure I'll find the time to do that though.
Re: 514 on the dyno [Re: AndyF] #804433
08/15/13 04:31 PM
08/15/13 04:31 PM
AndyF Offline OP
AndyF  Offline OP
I talked to a rep from Royal Purple and he said that 180 to 190 F on the oil temp was just fine. So I'm not going to worry about getting the oil hotter than that.
We figured out that the aluminum shavings were coming from inside the oil pump. I sent the pump back to Peterson Fluid Systems and they repaired it under warranty. Thanks to the guys from Peterson for that. The pump didn't have much time on it, but it was well past a normal warranty period since I bought it two years ago.
When I finished this round of testing I didn't think I had anything else to try but after a few weeks of thinking and talking I actually have a fairly long list of things that I'm looking into.
Stepping up to a larger header size with a shorter primary length is #1 on the list. I need to try going richer with the Q16 as well as trying more pan vacuum. Dwayne had some ideas on the heads so those will probably make the trip to his shop at some point.
Re: 514 on the dyno [Re: moparmanjames] #804434
08/15/13 04:37 PM
08/15/13 04:37 PM
AndyF Offline OP
AndyF  Offline OP
I don't have Dyno Sim but I do have PipeMax. The PipeMax numbers are fairly close to what we see on the dyno. PipeMax does say that I need .866 valve lift and I'm not quite there. But that is just a limitation with these heads.
PipeMax is recommending a 2.125 header that is 29 inches long with a 16 inch collector. The original PipeMax calculation that I did a few years ago told me 2 x 34 inch header. It will be interesting to see what difference it makes.
Re: 514 on the dyno [Re: AndyF] #804435
08/16/13 07:29 AM
08/16/13 07:29 AM
In The Hills
jughed Offline
jughed  Offline
In The Hills
Not sure if this has been asked before....any dyno sheet??????
Re: 514 on the dyno [Re: Performance Only] #804436
08/16/13 07:42 AM
08/16/13 07:42 AM
Q
Quicktree Offline
Quicktree  Offline
Q
Great work as always, andy!
Any dyno sheets you can post up?
Be interesting to see where the hp/torque curves overlay, I'd say the majority of the 500" stuff on here are aimed more toward true 'dual purpose' street/strip car....so more power up top at the expense of torque through the middle isn't always the best trade-off on a heavier car with street gears and an automatic.
Thanks!
Bobby
I think now that your dyno shows around 1.8 HP per cube, that engine has become quite the dyno mule. It makes me wonder if people across the country could follow that exact recipe and come up with the same numbers consistently. To think An EZ headed combo could make that much horsepower (928 HP so far)is surprising at the very least. I've seen guy's build B-1 combo's that only make about 25-50 HP more than that.
I have to admit that I too and I'm sure many others as well would really like to see the raw data from some of those dyno sessions. By that I mean all the actual meaningful stuff like BSFC, BMEP, SCFM, etc. etc. Admittedly I'm somewhat surprised at your unwillingness to share that info and so are many others that have shared their thoughts with me.
With all that aside, as an engine builder myself I have a pretty good idea how much time and expense has gone into getting the engine to where it is at this point. Thanks for sharing some of what you've done so far. I (and many others)just think it would be great if you would go to that next step on the dyno info.
i would love to see this motor put in a sorted out car and make some passes down the track. I doubt you would see a 929hp result
Re: 514 on the dyno [Re: Quicktree] #804437
08/16/13 10:56 AM
08/16/13 10:56 AM
Left Coast
BobR Offline
BobR  Offline
Left Coast
Thanks!
Bobby
Andy is a good dude but that dyno sounds like it's pretty happy.
Re: 514 on the dyno [Re: BobR] #804438
08/16/13 11:05 AM
08/16/13 11:05 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Thanks!
Bobby
Happy ain't the word for it.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: 514 on the dyno [Re: BobR] #804439
08/16/13 11:58 AM
08/16/13 11:58 AM
AndyF Offline OP
AndyF  Offline OP
Load cell reads correctly when we deadweight it.
Re: 514 on the dyno [Re: AndyF] #804440
08/16/13 12:39 PM
08/16/13 12:39 PM
Oologah, Oklahoma
Big Squeeze Offline
Big Squeeze  Offline
Oologah, Oklahoma
So post up a sheet....talk is cheap...what are you waitin for?
If you can't handle the truth, you're living a lie.......
Re: 514 on the dyno [Re: Big Squeeze] #804441
08/16/13 12:43 PM
08/16/13 12:43 PM
Q
Quicktree Offline
Quicktree  Offline
Q
heck lets find a car and put it in. think of the article you could write on that when it made a 7 second pass.
Re: 514 on the dyno [Re: Quicktree] #804442
08/16/13 02:13 PM
08/16/13 02:13 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
So far I have enjoyed this thread and found it interesting and beneficial. Instead of being passive aggressive with the and such (one of my pet peeves in business and life) it would be interesting to hear opinions of why some of you feel the dyno numbers are inflated. Is this based on head flow? Lack of displacement? Because nobody has used a Jesel valve train, dry sump, wilson ported intake, etc. on a relatively "small" engine with "sportsman" type heads?
Not trying to stir things up more just wanting to get some of this out on the table. I see your and raise you a
Re: 514 on the dyno [Re: Jeremiah] #804443
08/16/13 03:37 PM
08/16/13 03:37 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
YES you are...........
Re: 514 on the dyno [Re: Big Squeeze] #804444
08/16/13 05:21 PM
08/16/13 05:21 PM
Cab_Burge Online work
Cab_Burge  Online Work
I had treid to post a comment on another post about power, I had said to one of the east of the Rockie Mtn. engine builder that maybe all our west coast engine builders motors suck all the O2 out of the air when we dyno test so you guys back east can't match the power we achieve That comment disappear, maybe it was to controversial All kidding aside, I've seen similar results with a 526 C.I. motor (440 block)with ported -1 heads that flowed right at 370 CFM .700 with a decent solid roller cam and valve train, stock 440-3 intake and a stock type Holley 9375-2 HP it made 845 HP at 6300 RPM missing due to me using a set of dyno headers that where smaller on the exhaust port than the heads where, it started missing(intermittent small miss, not a steady miss on one or two cylinders) at 5200 RPM amd missed all the way to peak HP I ended trying those heads on two different short blocks with the same dyno headers, they both missed, neither short block missed with a set of SR heads that had the smaller stock size exhaust ports with the same headers, those heads where worth 50+ HP on both short blocks even with the miss AndyF gets a lot better parts in many cases for his testing than I can afford
Re: 514 on the dyno [Re: Cab_Burge] #804445
08/16/13 05:25 PM
08/16/13 05:25 PM
Q
Quicktree Offline
Quicktree  Offline
Q
and thats why we have 10 second 800hp dusters around
Re: 514 on the dyno [Re: Jeremiah] #804446
08/16/13 05:52 PM
08/16/13 05:52 PM
Oologah, Oklahoma
Big Squeeze Offline
Big Squeeze  Offline
Oologah, Oklahoma
What you should be asking is why he won't post up a dyno sheet..... .....everyone knows Cabs Dyno numbers are "happy" and that's OK since we all know it (except for Cab)...
Re: 514 on the dyno [Re: Quicktree] #804447
08/16/13 05:57 PM
08/16/13 05:57 PM
Chicago, IL
TonyS451 Offline
TonyS451  Offline
Chicago, IL
Come on Andy, quit slacking already. We need more data (and more books, and more parts comparing dyno testing, and innovative product development, etc..etc...!!! And make sure all that comes out of your pocket while you're at it! We want more!!
2 kids and a dog
Re: 514 on the dyno [Re: TonyS451] #804448
08/16/13 08:36 PM
08/16/13 08:36 PM
Oologah, Oklahoma
Big Squeeze Offline
Big Squeeze  Offline
Oologah, Oklahoma
Even if the dyno is happy, I still enjoy seeing the difference different parts make......
Sasquatch and an Andy F. dyno sheet..........both talked about, but never really captured..........
Re: 514 on the dyno [Re: Big Squeeze] #804449
08/16/13 09:39 PM
08/16/13 09:39 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
what did the modman intake do?
Re: 514 on the dyno [Re: sixpackgut] #804450
08/16/13 11:10 PM
08/16/13 11:10 PM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
Forget the Modman intake, that's just a smokescreen, a distraction. I found out through top secret unnamed sources working at the NSA, that a NightStar XS-14 unmanned aerial vehicle, operating at an altitude of 39,000 feet above the dyno facility, and using classified conctrete-penetrating gamma ray spectrometry, detected this product, The Tornado, being secretly installed inside the Indy Modman intake. A team of theorists, engineers and futurists at the NSA developed a theory which suggests that Andy is attempting to leverage the mild supercharging effect of the Tornado to achieve peak power levels beyond 1,000 HP, but he needed an intake manifold with a large enough interior plenum to fit The Tornado inside, which was the sole reason for selecting the Modman intake.
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: 514 on the dyno [Re: Quicktree] #804451
08/17/13 12:07 AM
08/17/13 12:07 AM
My Duster never had a 800 +HP motor in it, the last configuration of my 518 C.I. short block had a set of basicaaly stock Indy SR with M.W. ports, they flowed 340 at .700 lift. that combination made a best of 727 HP at 4300 Ft in Klamath Falls, OR, no Tornado in that motor The Duster ran 9.96 at 134.8 MPH on Oregon pump gas through the exhaust with the air cleaner on weighing 3450 lbs with me in it with that combination Now how does that compute The T/A eight SS converter I put in that car made .2 ET and .25 MPH differences(quicker) in the 1/8 mile, I'm not sure how much better in the 1/4 as I don't run the car that much in the summer at a 1/4 mile track. Bottom line is I tell you guys what the results are Big Squeeze is correct about the local Studka dyno reading happy for awhile. Not so after I took my 526 C.I. mule motor to Klamath to test it on the DTS dyno down thier. I watched the dyno operators calibrate both dynos so I'm confident that they both registered, measured, within 10 HP and 5 Ft lbs of each other on the same motor, mine with no changes to the motor after calibrating the dynos As far as AndyF and his results maybe some of you doubters ought to pitch in some cash to help pay for more dyno time with the stipulation that you get copies of the dyno sheets Some people do, some people talk.
