Page 6 of 19 1 2 4 5 6 7 8 18 19
Re: 514 on the dyno [Re: AndyF] #804272
03/06/11 02:29 AM
03/06/11 02:29 AM
AndyF Offline OP
AndyF  Offline OP
Where is Gorski? He usually chimes in on these threads when I use his wires. Speaking of that, I need to order up a custom coil wire so I can replace the MSD coil wire that I have on there now. Then it will be all Firecore. These are the 8.5 mm Firecore wires and they've been working great. Nobody else made a set of wires that fit a belt drive distributor.
Re: 514 on the dyno [Re: Performance Only] #804273
03/06/11 12:14 PM
03/06/11 12:14 PM
Oologah, Oklahoma
Big Squeeze Offline
Big Squeeze  Offline
Oologah, Oklahoma
i still stand by my other post here. there is so little actual info about the 514 it's almost as if it was written that way on purpose.
why not show some actual data? personally i wouldn't car if it made 600 hp or 1100 hp. you don't need to do it to prove anything, but when someone throws out HP and Torque numbers it sure would be nice to see the dyno data so people can read, absorb and learn from it.
X2..... I've asked something like 6 TIMES and still no answer to why there's no dyno sheet so we can check out things like BSFC numbers and the only reply so far has been "It is easy for those little sensors to get messed up and it is expensive to calibrate them so I don't really worry about it much. I don't worry about fuel economy with this engine, we just fill the tank up with race gas when it gets low."
It's not about fuel economy..... it's about how effecient that motor is (which it, obviously, takes a pretty effecient motor to make that much HP with the parts it has).....AND if it's easy for "those little sensors to get messed up", maybe the little sensor that spits out how much HP it's making is "messed up".....
I'll say it again by quoting myself;
Am I the only one that thinks Andy is ONE BAD-AZZ engine builder.....or that dyno is about 100HP HAPPY??????........ ......It'd be interesting to actually see some real proof.....
That's a nice way of giving him the benefit of the doubt......
Andy, POINT BLANK, again......I'm assuming there are motors out there that have been on that dyno with comparable numbers that have actually been raced, so it'd be interesting to find out what MPH they run and at what weight?????
If you can't come up with any, then it'd be great if you'd stop posting max HP numbers and focus more on just HP differences between the parts you change, which is still interesting.......
Just my opinion and a few, very simple, questions.......
If you can't handle the truth, you're living a lie.......
Re: 514 on the dyno [Re: Big Squeeze] #804274
03/06/11 01:25 PM
03/06/11 01:25 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Where the dyno numbers (to me) are particularly interesting is, for example...where in the curve does the Jesel rocker gear start picking up the TQ/HP....is it at a (street useable) 4000rpm or is is only in the 5200 and up area?
This is what is useful to the guys that are trying to learn and apply things...it's sort of like Engine Masters magazine....they don't post dyno numbers for the contests or any useful tech....so what the heck is the point for gearheads (like ourselves) to buy a magaizine (supposedly produced and geared toward appealling to the more tech-saavy reader) if it doesn't tell us anything of use? I think sponsors of the magazines put pressure onthe editors to dumb down the content compared to years past...the idea is to promote the builders and the parts they sell and keep the "sausage" (how to actually do it) a "Black Magic" mystery.....they're missing the boat and I see a direct correlation between the progressive lack of technical content in magazines to the lack of PAGES those magazines now contain There are thicker hand-outs inthe Sunday paper than there are in most magazines today, but that's O/T though somehow a bit related to the point i'm trying to express.
The pay-off to Dyno time and technical analysis of the data, is after all...THE ANALYSIS! Not taking anything away from Andy, but for example, I love the posts guys like Ryan and Fast68 do for us, I'd gladly pay a share of the dyno time to have access to that kind of information!
Andy, please keep it up, but also remember your audience here...As said, I would gladly be willing to kick-in a portion of dyno time (as others would I'm sure)...if the hard-core tech (that we all care most about) can come along with it.
WIZE
In Car:
Re: 514 on the dyno [Re: Streetwize] #804275
03/06/11 01:39 PM
03/06/11 01:39 PM
How about paying for some of my dyno time I have two motors that have beed dyno tested, one pump gas 518 and one race gas 527 C.I bracket motor that I have switched heads on between the two. SR with stock Indy valve sizes and 440-1 with 2.25 intakes I switched 440-1 from the 518 to the 527 and SR onto the 518 pump gas motor from the 527 bracket motor $500.00 dollars a day for dyno time in Kalmath Falls, OR on a DTS and the same amount per day in Madras, OR on a Studka that is now calibrated All assistance gracefully accepted
Re: 514 on the dyno [Re: Cab_Burge] #804276
03/06/11 01:44 PM
03/06/11 01:44 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
I'm your Huckleberry!
Now let's see who else will pony up...I'm sure a few others will
The "catch" is if you can't get enough 'contributors' to at least knock your cut of the dyno time in 1/2 (1/2 or $250 out of pocket would be pretty reasonable, right?) you only PM or E-mail the data to those who kicked-in
WIZE
In Car:
Re: 514 on the dyno [Re: Streetwize] #804277
03/06/11 01:49 PM
03/06/11 01:49 PM
The "catch" is if you can't get enough 'contributors' to at least knock your cut of the dyno time in 1/2 (250 out of pocket would be pretty reasonable, right?) you only PM or E-mail the data to those who kicked-in
If I was to get half I would share that information like all of those that helped wanted me to Some help, especially in this economy being retired, is way better than none
Re: 514 on the dyno [Re: Cab_Burge] #804278
03/06/11 01:59 PM
03/06/11 01:59 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
PM sent...Check or PayPal?
Now let's see who else is in...
WIZE
In Car:
Re: 514 on the dyno [Re: Streetwize] #804279
03/06/11 02:52 PM
03/06/11 02:52 PM
Quote:--------------------------------------------------------------------------------I'm your Huckleberry! Now let's see who else will pony up...I'm sure a few others will The "catch" is if you can't get enough 'contributors' to at least knock your cut of the dyno time in 1/2 (250 out of pocket would be pretty reasonable, right?) you only PM or E-mail the data to those who kicked-in  --------------------------------------------------------------------------------If I was to get half I would share that information like all of those that helped wanted me to  Some help, especially in this economy being retired, is way better than none
PM sent...Check or PayPal?Now let's see who else is in...
I don't want to steal any more of Andys post so maybe it is time for another, seperate posts, on sharing information, dyno costs and the results and who wil get that information
Re: 514 on the dyno [Re: Cab_Burge] #804280
03/06/11 03:09 PM
03/06/11 03:09 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Amen, Mr. Cab and I apologize (especially to my buddy Andy) for going O/T.
I have no doubt whatsoever the motor does everything that Andy sadi it does, the gearhead and Tech-junkie that I am can't help but wonder where and when in the powerband (specifically) the power comes from versus a more standard type build...that's all
I will say that I'm satisfied that above 5000 or so valvetrain stability really comes into play, to the point where personally I wouldn't build a 650-ish HP motor without something more stable than the OEM style cast-in pedestals....especially with a solid roller type spring!! I'd love to install an industrial type multi axis motion transducer into one of those cast aluminum pedestals (argualbly not even as strong as the oem cast iron) just to see how much shakin' is going on . I can't afford the Jesel stuff for a street build, but again the One-piece billet block (Race W2 style) pedestals really seem to help.
WIZE
In Car:
Re: 514 on the dyno [Re: FastmOp] #804281
03/15/11 03:27 AM
03/15/11 03:27 AM
AndyF Offline OP
AndyF  Offline OP
As long as you leave the dyno set up the same for each test it don't matter what the numbers are. The diffrences will still show up and should be real world numbers.
Wile the other guys want the dyno info I'd just like to see a few pics of the plugs to see how it's burnin
Here is a picture of a plug for you. These plugs have about 20 dyno pulls on them at 800+ hp.
Re: 514 on the dyno [Re: AndyF] #804282
03/20/11 02:30 AM
03/20/11 02:30 AM
AndyF Offline OP
AndyF  Offline OP
I started to pull the engine down to make a few changes. These Superformance intake gaskets work like a champ. We did a bunch of intake swaps on the dyno and the gaskets still look like new.
Re: 514 on the dyno [Re: AndyF] #804283
05/05/11 01:35 AM
05/05/11 01:35 AM
AndyF Offline OP
AndyF  Offline OP
My new 5 stage R4 pump showed up the other day from Peterson. I need to fabricate a mount for it and then we can get back on the dyno. I'm pretty sure there is another 20 to 30 hp in the oil system once we get things sorted out. The old three stage in the background is the pump that I have been using.
Re: 514 on the dyno [Re: AndyF] #804284
05/05/11 10:22 AM
05/05/11 10:22 AM
Quebec, Canada
Diablo Offline
Diablo  Offline
Quebec, Canada
Where are you gonna put all the suction lines? Run all four in the pan or???
Nice build
Re: 514 on the dyno [Re: AndyF] #804285
05/05/11 11:09 AM
05/05/11 11:09 AM
Central Oregon
Rodney Offline
Rodney  Offline
Central Oregon
I would consider it research, and development to please the owner of The Stuska Dyno and charge you {PM sent} to test this engine you are building.
Now that I'm back on my feet I am available to offer what I can.
Re: 514 on the dyno [Re: Diablo] #804286
05/05/11 04:25 PM
05/05/11 04:25 PM
AndyF Offline OP
AndyF  Offline OP
Yes, the pan has four scavange sections so the pump will just pull from there.
Rodney, I'd like to bring the 514 over for some dyno testing later this year. It would be fun to do that although it is a bunch of work getting an engine like this set up at a different shop.
Re: 514 on the dyno [Re: greendart408] #804287
05/05/11 04:48 PM
05/05/11 04:48 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
I wasnt there to see Andy dyno the 514 but, I race super dirt late models in the pacific northwest and run a sb2.2 alum. 415ci. that came from a very reputable engine builder from back east that claims it to have made 850hp. We installed it on the dyno that Andy uses and it made 762hp. There are alot of alum dirt late model motors built at this shop and most make 700 to 730hp in 430ci. arrangement. These motors will run with any dirt late model motors anywhere and alot of those supposedly make over 800hp dyno'd hp. Im posting this to verify what I know about this dyno and it is known locally to be stingy compared to other known ones in the area. Im not trying to the pot. Just giving my opinion of the dyno.
a friend of mine just dynoed a sb2 and it made 796...(358CI)
Mopar Performance
Re: 514 on the dyno [Re: AndyF] #804288
06/05/11 11:51 PM
06/05/11 11:51 PM
AndyF Offline OP
AndyF  Offline OP
I worked up a prototype mount for the R4 pump. I decided to go off the timing cover for this mount since it seemed to line up a little better.
Re: 514 on the dyno [Re: AndyF] #804289
06/05/11 11:53 PM
06/05/11 11:53 PM
AndyF Offline OP
AndyF  Offline OP
I also designed up a tapered spacer to work with the Wilson shear plate. We'll see how it works during the next dyno session.
Re: 514 on the dyno [Re: AndyF] #804290
06/06/11 12:01 AM
06/06/11 12:01 AM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
Nice whittelin' as usual!
Keith
Re: 514 on the dyno [Re: Dunnuck Racing] #804291
06/06/11 12:51 AM
06/06/11 12:51 AM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
WOW!! Great post Thanks!!
