Re: 514 on the dyno
[Re: Performance Only]
#804273
03/06/11 12:14 PM
03/06/11 12:14 PM
Posts: 1,491 Oologah, Oklahoma
Big Squeeze
Oologah, Oklahoma
i still stand by my other post here. there is so little actual info about the 514 it's almost as if it was written that way on purpose. why not show some actual data? personally i wouldn't car if it made 600 hp or 1100 hp. you don't need to do it to prove anything, but when someone throws out HP and Torque numbers it sure would be nice to see the dyno data so people can read, absorb and learn from it.
X2..... I've asked something like 6 TIMES and still no answer to why there's no dyno sheet so we can check out things like BSFC numbers and the only reply so far has been "It is easy for those little sensors to get messed up and it is expensive to calibrate them so I don't really worry about it much. I don't worry about fuel economy with this engine, we just fill the tank up with race gas when it gets low."
It's not about fuel economy..... it's about how effecient that motor is (which it, obviously, takes a pretty effecient motor to make that much HP with the parts it has).....AND if it's easy for "those little sensors to get messed up", maybe the little sensor that spits out how much HP it's making is "messed up".....
I'll say it again by quoting myself;
Am I the only one that thinks Andy is ONE BAD-AZZ engine builder.....or that dyno is about 100HP HAPPY??????........ ......It'd be interesting to actually see some real proof.....
That's a nice way of giving him the benefit of the doubt......
Andy, POINT BLANK, again......I'm assuming there are motors out there that have been on that dyno with comparable numbers that have actually been raced, so it'd be interesting to find out what MPH they run and at what weight?????
If you can't come up with any, then it'd be great if you'd stop posting max HP numbers and focus more on just HP differences between the parts you change, which is still interesting.......
Just my opinion and a few, very simple, questions.......
If you can't handle the truth, you're living a lie.......
Re: 514 on the dyno
[Re: Big Squeeze]
#804274
03/06/11 01:25 PM
03/06/11 01:25 PM
Posts: 9,881 Weddington, N.C.
Streetwize
Weddington, N.C.
Where the dyno numbers (to me) are particularly interesting is, for example...where in the curve does the Jesel rocker gear start picking up the TQ/HP....is it at a (street useable) 4000rpm or is is only in the 5200 and up area? This is what is useful to the guys that are trying to learn and apply things...it's sort of like Engine Masters magazine....they don't post dyno numbers for the contests or any useful tech....so what the heck is the point for gearheads (like ourselves) to buy a magaizine (supposedly produced and geared toward appealling to the more tech-saavy reader) if it doesn't tell us anything of use? I think sponsors of the magazines put pressure onthe editors to dumb down the content compared to years past...the idea is to promote the builders and the parts they sell and keep the "sausage" (how to actually do it) a "Black Magic" mystery.....they're missing the boat and I see a direct correlation between the progressive lack of technical content in magazines to the lack of PAGES those magazines now contain There are thicker hand-outs inthe Sunday paper than there are in most magazines today, but that's O/T though somehow a bit related to the point i'm trying to express. The pay-off to Dyno time and technical analysis of the data, is after all...THE ANALYSIS! Not taking anything away from Andy, but for example, I love the posts guys like Ryan and Fast68 do for us, I'd gladly pay a share of the dyno time to have access to that kind of information! Andy, please keep it up, but also remember your audience here...As said, I would gladly be willing to kick-in a portion of dyno time (as others would I'm sure)...if the hard-core tech (that we all care most about) can come along with it.
Re: 514 on the dyno
[Re: Streetwize]
#804275
03/06/11 01:39 PM
03/06/11 01:39 PM
Posts: 43,269 Bend,OR USA
Cab_Burge
How about paying for some of my dyno time I have two motors that have beed dyno tested, one pump gas 518 and one race gas 527 C.I bracket motor that I have switched heads on between the two. SR with stock Indy valve sizes and 440-1 with 2.25 intakes I switched 440-1 from the 518 to the 527 and SR onto the 518 pump gas motor from the 527 bracket motor $500.00 dollars a day for dyno time in Kalmath Falls, OR on a DTS and the same amount per day in Madras, OR on a Studka that is now calibrated All assistance gracefully accepted
Re: 514 on the dyno
[Re: Cab_Burge]
#804278
03/06/11 01:59 PM
03/06/11 01:59 PM
Streetwize
Weddington, N.C.
Quote: --------------------------------------------------------------------------------
I'm your Huckleberry!
Now let's see who else will pony up...I'm sure a few others will
The "catch" is if you can't get enough 'contributors' to at least knock your cut of the dyno time in 1/2 (250 out of pocket would be pretty reasonable, right?) you only PM or E-mail the data to those who kicked-in
If I was to get half I would share that information like all of those that helped wanted me to Some help, especially in this economy being retired, is way better than none
PM sent...Check or PayPal?
Now let's see who else is in...
Re: 514 on the dyno
[Re: Streetwize]
#804279
03/06/11 02:52 PM
03/06/11 02:52 PM
Cab_Burge
Quote:--------------------------------------------------------------------------------I'm your Huckleberry! Now let's see who else will pony up...I'm sure a few others will The "catch" is if you can't get enough 'contributors' to at least knock your cut of the dyno time in 1/2 (250 out of pocket would be pretty reasonable, right?) you only PM or E-mail the data to those who kicked-in --------------------------------------------------------------------------------If I was to get half I would share that information like all of those that helped wanted me to Some help, especially in this economy being retired, is way better than none
PM sent...Check or PayPal?Now let's see who else is in...
I don't want to steal any more of Andys post so maybe it is time for another, seperate posts, on sharing information, dyno costs and the results and who wil get that information
Re: 514 on the dyno
[Re: Cab_Burge]
#804280
03/06/11 03:09 PM
03/06/11 03:09 PM
Streetwize
Weddington, N.C.
Amen, Mr. Cab and I apologize (especially to my buddy Andy) for going O/T. I have no doubt whatsoever the motor does everything that Andy sadi it does, the gearhead and Tech-junkie that I am can't help but wonder where and when in the powerband (specifically) the power comes from versus a more standard type build...that's all I will say that I'm satisfied that above 5000 or so valvetrain stability really comes into play, to the point where personally I wouldn't build a 650-ish HP motor without something more stable than the OEM style cast-in pedestals....especially with a solid roller type spring!! I'd love to install an industrial type multi axis motion transducer into one of those cast aluminum pedestals (argualbly not even as strong as the oem cast iron) just to see how much shakin' is going on . I can't afford the Jesel stuff for a street build, but again the One-piece billet block (Race W2 style) pedestals really seem to help.
Re: 514 on the dyno
[Re: FastmOp]
#804281
03/15/11 03:27 AM
03/15/11 03:27 AM
Posts: 31,060 Oregon
AndyF
As long as you leave the dyno set up the same for each test it don't matter what the numbers are. The diffrences will still show up and should be real world numbers.
Wile the other guys want the dyno info I'd just like to see a few pics of the plugs to see how it's burnin
Here is a picture of a plug for you. These plugs have about 20 dyno pulls on them at 800+ hp.
Re: 514 on the dyno
[Re: AndyF]
#804283
05/05/11 01:35 AM
05/05/11 01:35 AM
AndyF
My new 5 stage R4 pump showed up the other day from Peterson. I need to fabricate a mount for it and then we can get back on the dyno. I'm pretty sure there is another 20 to 30 hp in the oil system once we get things sorted out. The old three stage in the background is the pump that I have been using.
