Re: 275's all around on a B-body ? [Re: AlexP] #80385
06/29/08 01:26 PM
06/29/08 01:26 PM
WA
P
pro451bee Offline
pro451bee  Offline
P
WA
A 5 inch backside wheel should clear allaround with a 17x9.5 wheel 275 40 17 in front will work but will probablly track in road groves real bad . I think in 17 inch size , 17x8 in front with 245 45 17 and 285 40 17 in back on a 9.5 or 10 wide rim 4.5 back side all around . Also , on a large B boby a 26 inch tire is a bit short and a 285 40 18 inch size in back looks nicer at 27 inches tall . 5 inch back side is usually the most back side you can use without rubbing .
Re: 275's all around on a B-body ? [Re: pro451bee] #80386
07/01/08 12:14 AM
07/01/08 12:14 AM
So Cal
autoxcuda Online content
autoxcuda  Online Content
So Cal
Why would it track bad? This A-body with 275/40/17's doesn't seem to track bad.
When you lower the car down the smaller diameter tire doesn't show as much. But a 245/45/17 is about the same diameter as a 275/40/17. But one has more footprint and grip.
Re: 275's all around on a B-body ? [Re: autoxcuda] #80387
07/01/08 12:31 AM
07/01/08 12:31 AM
WA
P
pro451bee Offline
pro451bee  Offline
P
WA
Im sure the wide ones work great at the track , but hiway grooves are very anoying in my neck of the woods . Heck even new Vipers can drive you crazy around here .crazy:
Re: 275's all around on a B-body ? [Re: pro451bee] #80388
07/01/08 09:41 AM
07/01/08 09:41 AM
Fort Worth, TX
Clair_Davis Offline
Clair_Davis  Offline
Fort Worth, TX
I think if you've got several degrees of +caster, bump steer is "fixed" (as good as it can get), and the scrub radius isn't zero OR some huge number, then tramlining or waller-fallerin' or whatever you want to call following the ruts in the road should be minimized. There's just going to be some that you can't get around when comparing the forces the road puts on a 205/70-14 vs. a 275/40-17.
Clair
Re: 275's all around on a B-body ? [Re: AlexP] #80389
07/03/08 06:54 PM
07/03/08 06:54 PM
Covington Georgia
RV2 Offline
RV2  Offline
Covington Georgia
I cant get the pic any larger but maybee it gives you an idea, 275 60 15 on 15x8 all around.
